Brighter reverse lights?? 2016 Panamera GTS
Old Jan 25, 2019 | 11:56 AM
  #46
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
WOW, looks very good, you still plan on trying the 100W'ers?
Old Jan 25, 2019 | 12:59 PM
  #47
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
No, I cancelled my order because I think they will melt part of the tail light ***'y and don't want a $$$ fix on my hands.
Old Jan 25, 2019 | 02:03 PM
  #48
ciaka's Avatar
IMO wise move. Could melt the housing plus cause other electrical problems. That would be the last thing anyone with a Porsche needs (where electrical issues are the Achilles' heel of the car).
Old Jan 25, 2019 | 02:45 PM
  #49
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Too bad there isn't an aftermarket solution that can solve this issue. Something along a more aggressive looking lower bumper diffuser and extra reverse light.
Old Jan 25, 2019 | 02:57 PM
  #50
LGARCIA's Avatar
5 Year Member
Here is an example with a carbon diffuser I had with a light combo on a Nissan 370Z...
For the reverse light you would need it to be white leds.....
Old Jan 25, 2019 | 03:19 PM
  #51
DogWood's Avatar
5 Year Member
Nice thing is the battery is in the back, should be no problem getting power
Old Jan 25, 2019 | 03:54 PM
  #52
DogWood's Avatar
5 Year Member
understandable, someone answered the question about the lumens outputted by the ones got, they are rated at 520lm ea.
Old Mar 17, 2019 | 10:18 AM
  #53
DogWood's Avatar
5 Year Member
Got a package from China yesterday
I had tried to order the same lights as skiracer, but they where no longer available on Amazon, so I got these, 50 watts 900lm!! (also amazon)
the camera does it's best to adjust for the available light so the dramatic difference is hard to see in these, but if you look carefully there are some good clues.
BEFORE:
AFTER:
I took a picture of the part tag on the housing, if someone has the housing without the access hatch they might be able to find some that has it.
if you can find some from a salvage yard for a good price the upgraded lights are worth it.
of course that is assuming the tag on the non hatch ones are different....
Old Mar 18, 2019 | 07:35 AM
  #54
ciaka's Avatar
What was that bulb number and link in amazon? Feeling lazy today, help much appreciated. Thanks.
I take it you are pleased?
Old Mar 18, 2019 | 09:12 AM
  #55
DogWood's Avatar
5 Year Member
here you go ciaka
https://www.amazon.com/gp/product/B07MV6QVZ2/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07MV6QVZ2/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
plug and play and a very noticeable improvement, not bad for $25 they also arrived about 5 days faster than predicted
you'll want to check your tail light assembly before ordering them, make sure you have the access hatch
Old Apr 21, 2019 | 04:56 PM
  #56
Kayvan1347's Avatar
5 Year Member
Kayvan1347 is infamous around these parts
Hi Dogwood,
this one comes in 80w version too. Since it is LED it shouldn’t get hot to damage the housing . Do you think 80 W works or it is better to use 50 W?
also is there any cable/harness comes with it?
the other one that someone else used it and was 30w have a cable attached to it?
Old Apr 21, 2019 | 07:25 PM
  #57
DogWood's Avatar
5 Year Member
you're right, the LEDs shouldn't get very hot but I'd be more worried about the wiring carrying more current than it was designed for
no cables or harness needed, plugged directly into the stock harness
Old Apr 21, 2019 | 08:21 PM
  #58
Kayvan1347's Avatar
5 Year Member
Ok thanks for infos.
then I will go for 50w as the same you did. I haven’t look at tail light yet. I hope mine wasn’t one those sealed ones that can’t be open. My car is Panamera 4 2013.
Old Apr 30, 2019 | 12:10 AM
  #59
Kayvan1347's Avatar
5 Year Member
i haven’t got the bulb yet but I thought to ask the manufacturer about the power consumption. I really haven’t seen any LED bulb with actual 50 W power consumption. So I asked them and this is the reply:
Hi,so sorry, 50W is theory power but not actual power, actual power is about 7W
so I saw the list of the bulbs on the tail light. I think the most you can go is 16 W. So if you find the 100W LED the actual power should be around 14 W.
Old Feb 6, 2020 | 11:36 AM
  #60
trickifish's Avatar
trickifish is infamous around these parts
[QUOTE=skiracer13;4762652]Glad to help - here's a pic of the reverse lights on my garage door - not headlights...
Very bright and very white![ Success 🥳 before I get cutting, I have the sealed reverse bulb casing 🙄 Reverse lights are rubbish on my 2012 Panny. Please can you confirm which bulbs you went for, or anybody have a more powerful upgrade? And did you have to cut out the back and add the new part with seal
