Brighter reverse lights?? 2016 Panamera GTS
Old Feb 6, 2020 | 11:46 AM
  #61
trickifish's Avatar
trickifish is infamous around these parts
Originally Posted by skiracer13
Glad to help - here's a pic of the reverse lights on my garage door - not headlights...
Very bright and very white!
Originally Posted by DogWood
here you go ciaka
https://www.amazon.com/gp/product/B07MV6QVZ2/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
plug and play and a very noticeable improvement, not bad for $25 they also arrived about 5 days faster than predicted
you'll want to check your tail light assembly before ordering them, make sure you have the access hatch
Hi did you go for the 50w as they do an 80w
Old Feb 6, 2020 | 12:16 PM
  #62
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
I went with the 50w, was a bit worried about the wires, didn't want to push it
Old Feb 6, 2020 | 05:44 PM
  #63
ciaka's Avatar
Agree. Dont over do it with wattage, or you will get melted socket, which you will have to replace.
Old Feb 6, 2020 | 07:16 PM
  #64
970gts's Avatar
5 Year Member
970gts is infamous around these parts
Trickifish….I couldn't replace the bulbs for my reverse lights. I added a couple of Oznium sealed LED's on either side of the license plate. Electrically spliced into the reverse light wiring. I think the post was "Auxiliary Reverse Light". It helped a lot.
Old Mar 2, 2020 | 02:21 PM
  #65
drewman75's Avatar
drewman75 is infamous around these parts
I am having the same issue as 970gts. Looks like my tail lights are the newer version with the reverse being a white strip along the bottom (image below). By the looks of them, I would assume they are already LED. But I have the same issue as everyone else in the thread with very low light when backing up at night and basically being able to see nothing in my rear camera. Anyone know if there is a way to possibly upgrade the LEDs in these?
Old Mar 5, 2020 | 09:31 AM
  #66
Stringbag's Avatar
Stringbag is infamous around these parts
If you are in the UK these LED bulbs are fantastic.
So much brighter than the original bulbs. Now I can actually see at night in my reverse camera!!
Oh, and they don’t need resistors (well they haven’t set off any warnings on my 2010). And they won’t burn your wiring up either. They pull 0.7A vs 1.3A for the original incandescent bulb.
https://www.auto-lighting.co.uk/prod...ens-WHITE.html
Old Oct 23, 2021 | 09:30 AM
  #67
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Reviving this thread. Now that winter is coming here in the Great White North, I need more reversing light! Unfortunately, I have the sealed tail light units. Have a 2014 4S.
Can anyone confirm if they actually cut open a sealed tail light and managed to do an LED bulb swap? Other suggestions for more light in the back are welcome as well.
Also, will changing the license plate bulbs to LED help gain more light?
As always, thank you in advance!
Old Oct 23, 2021 | 10:03 AM
  #68
DogWood's Avatar
5 Year Member
vbk123 I suspect your best option is along the lines of what 970gts did in post #64
Old Oct 23, 2021 | 11:21 AM
  #69
vkb123's Avatar
5 Year Member
Thanks @DogWood ! I remember @970gts’s solution to this problem. Very creative and I’ll likely need to go down the same path. Wondering how the Ozinium lights attach to the sides of the license plate? Screw in or double sided tape?
I believe @elShiz was considering “opening up” a sealed unit to try a bulb swap? Any updates on this or are the sealed tail light units confirmed to be non-servicable?
Also came across this on the Cayenne forum where lack of rear light also seems to be a problem. Anyone have any experience with this?
Amazon Amazon
Old Oct 23, 2021 | 11:54 AM
  #70
DogWood's Avatar
5 Year Member
wow that looks cool, but damn is it pricey
Old Oct 23, 2021 | 12:34 PM
  #71
ScottDy's Avatar
ScottDy is infamous around these parts
I have the Ozinium lights on my 4S, they attach by very strong 2 sided 3M tape.
Old Oct 23, 2021 | 12:42 PM
  #72
vkb123's Avatar
5 Year Member
Thanks @ScottDy ! Will be considerably cheaper that license plate light option. Does the tape stand-up to regular washing including power washer? Easy mod to do? Auto electric is NOT my forte.
Old Oct 23, 2021 | 02:00 PM
  #73
ScottDy's Avatar
I haven't power washed my car before so I don't know but it should, the tape is very strong and the lights don't weigh much at all. The install is pretty simple although you have to splice into the reverse light wiring at the taillight connection. It's pretty simple, if you decide to do it let me know and we can go over it.
Old Oct 26, 2021 | 08:36 PM
  #74
vkb123's Avatar
5 Year Member
Hey ScottDy! Looks like I’ll have to do the Oznium mod to get more rear light. Any tips on how to get the wires from the installed location next to the license plates and into the bumper? Also any help on how to splice these wires into the tail light wiring is very much appreciated! Thanks in advance!
Old Nov 2, 2021 | 12:04 PM
  #75
ScottDy's Avatar
Sorry for the late response, I usually get an email when someone replies to a thread I'm involved with. I've got a few things going on right now and I'm supposed to be going on vacation Thursday night so I haven't got time for a detailed response right now but in a nutshell...
The lamp modules can be mounted at the top edges of the license plate frame with the wires facing up (there is a channel in the back of the lamp base that the wires will fit into so that it mounts flush). The wires can be brought up towards the trunk rubber molding and tucked under the molding and brought to either the left or right taillight (i took one to each side but 970GTS just went to one side and spliced the wires from both lamps together and that worked as well) You need to remove the taillight(s) and if you look closely there is a small gap between the taillight opening and the hatch opening that you can get the wire through. Once you do this you just need to connect the LED hot wire(s) to the backup light wire at the taillight plug (it's the wire in the A3 position on the plug and connect the ground to A2. I used these wire connectors I found on Amazon,
Amazon Amazon
They're small waterproof I believe and make for a neater installation. I think that's about it, let me know if you have any questions.
