Weird/Strange Panamera Noise
Old Dec 3, 2019 | 04:16 PM
murci930's Avatar
murci930 is infamous around these parts
I will be shocked if anyone has experienced this same problem. My PTT does the strangest F!@#$%@g thing when it gets wet underneath. It starts making this noise, like something is vibrating and bouncing around between the front wheels and driver and passenger seats. It ONLY happens when it gets pretty wet, BUT it is not consistent. Meaning, sometimes when idling it would be faint, while driving it comes out of being very loud to then eventually going away after driving at a consistent speed.
When it does this, it sounds like the exhaust is muffled.
I know this all sounds bizarre, but it is the strangest thing,,,
Old Dec 3, 2019 | 04:25 PM
Mazurda's Avatar
Mazurda is infamous around these parts
Throw it on life and check stabilizer bar and bushings
Old Dec 3, 2019 | 04:29 PM
murci930's Avatar
Thank you! I will check it out, it does sound just like them, but when I replaced on my 9964s it made the noise consistently wet/dry
Old Dec 3, 2019 | 04:30 PM
murci930's Avatar
And NOISE****
Old Dec 3, 2019 | 04:53 PM
Mazurda's Avatar
And NOISE****
Any noise when going over bumps or dips in the road? More noticeable when cold out?
Old Dec 3, 2019 | 04:58 PM
murci930's Avatar
That was what made it so obvious on my , it hasn't made any noise yet (aside from a little bit of crunching). It is definitely worth checking out
Old Dec 3, 2019 | 05:39 PM
stealthn's Avatar
stealthn is infamous around these parts
Broken cat maybe?
Old Dec 5, 2019 | 01:57 PM
XLR82XS's Avatar
My theory may be bizarre as well: moisture affecting the crank/under-drive pulley and/or belt. Water may be somehow causing noise while the pulley is spinning (your idle noise). Going from loud to quiet may be centrifugal force due to engine speed increasing may be drying the pulley as your drive.
So, maybe it's a pulley and/or worn drive belt issue?
Old Dec 6, 2019 | 06:32 PM
murci930's Avatar
I just had the car in for a recall and they did mention the belt needing to be replaced soon, while your theory is a little bizzare it does make the most sense as it is only when heavily wet not just a sprinkle... definitely work investigating Thank you!
Old Dec 10, 2019 | 12:04 PM
XLR82XS's Avatar
I know - totally bizarre but that's the only thing I could think of involving water. Hope it all works out.
Old Dec 11, 2019 | 06:24 PM
ciaka's Avatar
Here is another idea thrown out there, have you checked your radiator fans? What if part of one blade is cracked, or something is stuck there? Check the fans.
Ed1
Nov 18, 2013 11:19 AM
seattle_sun
Mar 11, 2013 02:53 PM
SR996
Apr 4, 2006 05:10 PM
