Panamera Transmission pan leak
I have threads on pdk, trans, etc. Read before.
bottom line, temp not a concern for panamera trans.
Recommend new bolts yes. Usually come in a kit. Get good kit so it won't leak.
Service manual from porsche does not use sealer. I did not either. Nor won't dealer.
Make sure it's level.
Read my diy on the change before you start.
Torque very important and tighten sequence too.
Oem fluid only FFL3
Open fill hole first to make sure yosure fill car after you drop oil.
did I say read the diy first?
Oem fluid only FFL3
Full PDK service - Fluid and Pan/filter. Do I need to replace all the bolts? I have Durametric it is useless, No temp monitoring. What diagnostic equipment I need beside PIWIS3? I am so tempting to buy PIWIS3 from VXDAX, but Jesse said it is not plug-n-play with my old Dell Lat Laptop. Porsche just quotes $1150 for PDK service with 10% discount. LOL ... what the heck ...
I also notice about
I greatly appreciate your feedback.
I also notice about
Trans Pan Sealer - Porsche (000-043-305-73)
I guess I need the sealer to make sure it will be no leak ...I greatly appreciate your feedback.
Thank you, Ciaka. Well Said ... Save your PDK procedure on my bookmark. https://www.6speedonline.com/forums/...id-change.html
"Torque very important and tighten sequence too", I did not see this information in your procedure. I was thinking of you and plan to ping you.
Many Thanks ...
Many Thanks ...
Now I k iw what happened. Look up my diy for gear shift position sensors. Shows you all torque and sequence for Tran pan bolts, along with bunch other things too.
Many Thanks ...
Many Thanks ...
I see Dr.Ciaka posting on the transmission sensors, Amazing ... https://www.6speedonline.com/forums/...placement.html
I don't think I need to do anything more than to replace the Pan and Fluid for my car. I don't have the TRANSMISSION FAULT Error code ...
I am ready to GO. I need a Tester either PIWIS or FOXWELL or iCarSoft POR V3.0. I will figure it out. I read through the PDK service manual. I see all information you put it on your DIY.
here is the attached PDK service for any memebers who like to know more.
MANY THANKS.
MANY THANKS.
