Windshield Washer Not Working 2010 Rapide
Hi All, Nothing happens when hitting the windshield wash button in the car. No pump noises or attempts to spray.
I checked all the fuses with a multimeter, and found fuse for the headlight washer was burned out, and replaced that. Now sporadically will have the headlight washer spray(misaligned and for some reason aims at the windshield, LOL). Saw a post about a timer & them only working with headlights on. Looking forward to getting home to try this. Didn't occur to me that could explain them working every so often.
Either way. Nothing from the windshield spray nozzles. On the diagram I found there doesn't appear to be a fuse dedicated to windshield washer or labeled as such. Does anyone know if there's a relay for the windshield washer pump, and which one it may be? or have any other ideas for troubleshooting? Any help is greatly appreciated.
Did you try checking for 12V getting to the windshield washers pump?
I had the same issue, verified I had 12V all the way down, replaced the pump itself, and everything was back to normal.
How would testing voltage work? Someone in the car would need to activate, While I have the wheel off and check for voltage?
There’s no other relay or fuse that specifically handles that pump? Would it be strange the headlight washer pump has a fuse but that one doesn’t.
Fuse is F48 (15A) and relay is R7A on the CEM.
Are your wipers moving when you push the button on the stalk or not at all? (The bonnet needs to be closed for the wipers to activate).
Yes, you need someone to activate the wipers while you read voltage on the pump plug.
You’re a prince and a gentleman. Thank you man. I put my code reader to see if there’s anything helpful there. My thinkdiag had codes for open circuit to ground for rear wiper, rear washer relay and for front washer relay. I’m pretty sure it’s the relay now with this info.
Funny enough, I did that with a cheap used one from ebay, but this weekend going to test with a multimeter to see if there's power going to the pump. It's possible the pump they sold me was also defective.
That's not trivial actually. I'm going to test this weekend and see if it's needed. How are you guys finding cross over part numbers? The AM part from scuderia is $300 when it's at best a $50 Ford motor co part. Any one know the cross over part number to get from Ford or Volvo?
Jaguar part number: C2C30350 or C2S4065
Genuine part:
https://rimmerbros.com/Item--i-C2S4065
I think this is it. Aftermarket one from Eurospare for under $15:
https://www.autohausaz.com/pn/EU-C2S...z7FwA1_vbXIxVS
Genuine part:
Genuine part:
Genuine part:
They're just standard relays, you can use the part number / reference on them to source.
Joe Boccia
Bentley
Aug 30, 2024 11:58 AM
