Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Old Mar 17, 2007 | 02:53 PM
  #2446
mt72's Avatar
mt72 is infamous around these parts
Originally Posted by cjv
Heck, we have waited this long already. Actually, I want a clear mind, without being rushed, when this motor is assembled. They rushed one the other day and it is one of the motors now being rebuilt at their cost. Even if they pay for it, I don't want to have to go through the delay of getting parts again.
We are having the Garrett Engineer's making a recommendation regarding the turbo's.
Let us know the out come on the engineer's have a good week-end !!!
Old Mar 18, 2007 | 02:51 AM
  #2447
cjv's Avatar
cjv
Moderator
I just received an interesting e-mail. I blanked the sender's name and country of orgin. They have done a fair amount of work on KA's motor. Needless to say, they are not an ordinary company. I can hardly wait to see what they come up with regarding turbo's and intake system.
Everytime I believe I'm finished ............. something new comes along.
Good morning Chad,
We have a project from (blank) based upon the 996 TT engine starting next month. It takes the rest of this month to get organized with parts etc.
I think this will be very similar to yours. We are at present spec’ing out the engine. The reason for contacting you is that we are in the middle of the Turbocharger design. Once we have decided upon a Turbo configuration, I will forward the info on. I think there may be some differences in engine spec, so I thought we should ask now. Do you know the final static compression of your engine? What is the exhaust design? If this information is proprietary, I understand. Please do not feel you need to supply if you do not wish to. The selection of Turbine wheel Trim and Turbine Housing size is important and the static compression and exhaust design, (pipe size, pipe length, merge design, primary to collector timing etc., dictates the Exhaust design of the Turbocharger. We have a lot more choices in Turbocharger parts and combinations than what is typically offered up for the street Tuner.
Although there is no real requirement for performance, the customer wants as much as possible I’m sure. Our goal is to produce the most Torque we can over the broadest RPM range.
The engine will be a 4.0L or 3.99L actually using the same parts as your new Grand Am prototype engine. The development of this engine is very useful now. We are looking at producing a new Intake system for this engine. This work will be done in (blank) for us. It is hoped that some of the Intake system that was developed for us for the Prototype engine can be used.
(blank)
Old Mar 18, 2007 | 08:35 PM
  #2448
mt72's Avatar
interesting
Old Mar 19, 2007 | 01:34 AM
  #2449
user 70823244's Avatar
user 70823244 is a splendid one to beholduser 70823244 is a splendid one to beholduser 70823244 is a splendid one to beholduser 70823244 is a splendid one to beholduser 70823244 is a splendid one to beholduser 70823244 is a splendid one to beholduser 70823244 is a splendid one to beholduser 70823244 is a splendid one to behold
..Huh? "Grand Am"
Old Mar 19, 2007 | 11:01 AM
  #2450
teflon's Avatar
teflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant future
Originally Posted by werksracer
..Huh? "Grand Am"
Porsche powered Daytona Prototype that races in Grand Am.
Greg A
Old Mar 19, 2007 | 12:23 PM
  #2451
cjv's Avatar
cjv
Moderator
Greg A
Greg,
These motors are designed around the limit of under 4L. This was accomplished with a 80 mm crank and 102 mm pistons/liners.
Neil Harvey of Performance Developments did the heads, cams, crank and rods. The crank and rods were done in conjunction with Arrow Precision from the UK.
www.performancedevelopments.com
Old Mar 20, 2007 | 01:54 AM
  #2452
OH,
you see I thought the email TO cjv was saying, YOUR Grand Am engine, emphasis on YOUR.
Old Mar 20, 2007 | 11:08 AM
  #2453
cjv's Avatar
cjv
Moderator
OH,
Just because you build a NASCAR, INDY, etc. motor doesn't mean you have to run it in NASCAR, Indy, etc. What is significant about this motor is it is in the frontier stages and the development costs we have paid (cams, crank, rods) have us right up there in the technology. We are not following anyone. Our people have had some visits from some very notable teams.
It will probably take a little time before these parts filter down to the tuners not activly supporting this new class. The good news is, these advancements will be available alot sooner than normal to the general public.
Old Mar 22, 2007 | 11:50 PM
  #2454
cjv's Avatar
cjv
Moderator
Old Mar 25, 2007 | 01:53 AM
  #2455
cjv's Avatar
cjv
Moderator
Years ago Duane B let me use his 986Host site for many of my pics. The site was down for along time and recently came back to my surprise with the pics. I remost some lost ones.
Nitrous Injector.
Nitrous CF bottle
Nitrous Controllers
Y Pipe
Front Brakes
Old Mar 25, 2007 | 02:03 AM
  #2456
cjv's Avatar
cjv
Moderator
Special Europipe Exhausts with 3 Kats
Ruf Short Shifter
IC's
Hard Piping
Old Mar 25, 2007 | 02:11 AM
  #2457
cjv's Avatar
cjv
Moderator
Double Jacketed Y Pipe for Liquid CO2 Cooling of Charged Air
Battery Difference
Old Mar 25, 2007 | 02:20 AM
  #2458
cjv's Avatar
cjv
Moderator
962/GT1 Three Index Oil Pump
Battery Install
Three disc lightweight clutch
Stock 440 vs 1000 cc injector
Old Mar 25, 2007 | 02:23 AM
  #2459
KhanNSX's Avatar
KhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud of
So these are pics of an old setup? Just curious because the beggining of these pics you said something about lost(old?)pics?
Old Mar 25, 2007 | 02:30 AM
  #2460
cjv's Avatar
cjv
Moderator
Instrument Cluster
Roll Cage/Liquid CO2 for intake charge air cooling
Nitrous Controls/IC in/out/delta gauge
Tranny Cooler
Tranny Cooler Pump
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
