Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Old Jun 4, 2007 | 11:44 AM
  #2551
sharkster's Avatar
Chad what we did on the 3.8 was make things "look" as stock as possible. Anything that had any red/blue or other colors we made black and/or silver. We also tell people to keep their stock airboxes for smog-time since it's easy to change. I also make sure no exhaust/headers are "shiny".... blast them.
Old Jun 4, 2007 | 12:15 PM
  #2552
cjv's Avatar
cjv
Moderator
sharkster,
I'm with you on the colors and the "look.". My indecision now is things like the external waste gates, pulling the air right off the turbo intake's. Routing the air from the stock or even a EVO set up is really restricting on big turbo's. There just isn't enough room to suficiently snake large enough piping from the existing filter location to the turbo intake. On the other hand, it isn't worth it if you fail the smog visual. I'm really considering using the TIAL hybrids with the internal wastegates even though the power won't be as much.
Any ideas?
Old Jun 4, 2007 | 02:52 PM
  #2553
sharkster's Avatar
Hey CJV... my car (s) run the Tial hybrids and we have passed GT700s and 800s. Even visually! But with external waste gates there's just no way they can pass you. That's the first thing they look for with all the Supras, EVOs etc... The waste gate manufacturers _always_ use these silly colors/polish that makes them really stand out not to mention the piping. If I were you I'd go with the hybrids. Yes it'll sacrifice some power but on your car... I don't think it'll matter Having said that I've only done this on the 28s and 30s so far. If you're using something larger like a GT35 or 42 there's just no way around it- you'd have to use external waste gates to make those things work right.
Old Jun 4, 2007 | 03:48 PM
  #2554
cjv's Avatar
cjv
Moderator
sharkster,
My thoughts exactly. I have a set of TIAL laying around. Here are some pics. I know they won't have the same power as the 35's but we won't have the testing issue to worry about.
Old Jun 4, 2007 | 04:03 PM
  #2555
cjv's Avatar
cjv
Moderator
Old Jun 4, 2007 | 04:09 PM
  #2556
sharkster's Avatar
hah those are _exactly_ the same as the ones on my car. I'm heading out to EVO tonight but once the car gets back from tuning in the next week or so you're welcome to see how responsive they are. Those are the same ones as mine with the .50 AR. The ones now have a newer style housing and .76 I believe...
Old Jun 4, 2007 | 04:17 PM
  #2557
cjv's Avatar
cjv
Moderator
sharkster,
I guess the question now would be the MAF. Our current MAF is located just prior to the throttle body (high pressure side). This would stick out like a sore thumb. I wonder if we could make it work in the stock position on the low pressure side?
Old Jun 4, 2007 | 04:23 PM
  #2558
cjv's Avatar
cjv
Moderator
The hot sides that I have are from a 1995 GT2. The housings and impellers have been modified a bit ( you can see grind marks) as far a flow.
Just not sure how to approach the MAF as it relates to the GT3 software transplanted to 996tt ecu. I'm sure there is an answer. What do you know about the Hitachi MAF that is recently being used?
Old Jun 4, 2007 | 11:55 PM
  #2559
sharkster's Avatar
Originally Posted by cjv
sharkster,
Yep that's an important point. So you've got something similair to protomotive's set up then with that y-pipe? It would look very suspect like that Your old set up was the scargo y-pipe and then stock (ish) airbox with the maf in place right before the CF plenum. That's basically how mine is right now (albeit a hitcahi).
Old Jun 4, 2007 | 11:57 PM
  #2560
sharkster's Avatar
I remember you telling me they were more honed out and hard to get You've got a very different situation there with that GT3 ECU and MAF close to the TB. I'd say any smog guy that looks at the diagram (emmisions one) on the decklid to see how the plumbing works isn't going to be happy. I'm still learing/find out on the Hitachi but it now reads properly for the high hp applications and I'm just glad that 700/800s are going this way...
Old Jun 5, 2007 | 07:56 PM
  #2561
cjv's Avatar
cjv
Moderator
sharkster,
Just had another long talk with Rob today. He wants to go all the way. We just took delivery on a set of 104 mm pistons/liners. We are waiting for the follow up stroker crank/rods. We decided to go for the 4.3 L motor to meet the displacement needed for the turbo's.
Old Jun 5, 2007 | 11:01 PM
  #2562
CLS's Avatar
CLS
CLS is infamous around these partsCLS is infamous around these parts
So....when do you think you'll have her on the road now with this change Chad?
Old Jun 6, 2007 | 01:22 AM
  #2563
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
still think you'll make your dedline of mid-summer? I hope you do Chad....
Old Jun 6, 2007 | 08:26 AM
  #2564
cjv's Avatar
cjv
Moderator
It will be complete this summer. Arrow Precision has already built one crank for us. We should have this one by early/mid July. Interestingly, these Arrow Precision racing cranks are made from billet, the turbo and GT3 motors use a forged crank.
Old Jun 16, 2007 | 07:38 PM
  #2565
cjv's Avatar
cjv
Moderator
I just looked and it was back on April 23rd that my heads and liners were suppose to be sent out to be o-ringed. That was 52 days ago and still counting.
I've lost all interest in this project. It's time to religate this project to a time capsule in the warehouse. Time to move on. Sorry it is ending this way.
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
