Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Rating: Thread Rating: 90 votes, 4.16 average.
Old Nov 22, 2003 | 05:55 AM
  #316
cjv's Avatar
cjv
Moderator
No budman, I replaced my Unichip system over a year ago. The reason it was replaced was we experienced too many related code fault problems after 500 rwhp.
My concern with any other add on boxes is code fault. Although Promotive has said I would not experience any code faults related to this unit.
Old Nov 22, 2003 | 06:00 AM
  #317
buddyg's Avatar
Gotcha, you said your "past experience with Unichip" I am a little slow this early. What the heck are you doing up so early it is like 5 am over there! Go to bed you goofball!
Old Nov 22, 2003 | 02:50 PM
  #318
cjv's Avatar
cjv
Moderator
Kevin,
There simply isn't enough time to do all the work and then re tune. It's still going to be a nail bitting event seeing who comes out as the top dog.
Old Nov 22, 2003 | 03:25 PM
  #319
Todd of CA's Avatar
Todd of CA is infamous around these parts
Chad,
although I had mentioned waiting a week till Tyson's car is clear, we could take it in earlier and have the shop guys start with the mechanical install. Then when I'm ready, I could get the emulation equipment in your car and do the live tune shortly after tyson's.
As I told you over the phone, we've been running these injector drivers on 993's, and 993tt's since about 1995 or so and had great success with them.
It's just been recently that the 996tt's are outpacing the saturated injector technology that it's even been neccesary. But that's actually the good part
Now, let's get enough fuel in there to see when those rod's will go <-- Probably not a funny joke
Just let me know, and I'll get on it either way.
The programming/retune shouldn't be too much of an issue with the larger injectors.
I'm toying with a 996na engine converted to twin-turbo with our 4.05L kit and swapping injectors around is really a non-issue.
It's been fun though. just .3 bar makes 462hp, and .5 bar so far has made 550hp... At the crank. I just keep running out of mass flow/injector/program, etc. It's based on the na program and hasn't been too agreeable thus far, but the power numbers are just great It shouldn't take over .75-.8 barfor 600hp at the crank. And it's making about equal torque to power right now. Too bad it's not an open project, the lower end of the engine is built for 1.2 bar
Old Nov 22, 2003 | 03:41 PM
  #320
Ruf-Racer's Avatar
Ruf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura about
Tyson,
Just maybe you are not such a dark horse after all!
R
Got a cage yet?
Old Nov 22, 2003 | 04:01 PM
  #321
cjv's Avatar
cjv
Moderator
R,
I don't believe Tyson was ever a dark horse. I believe he has an excellent chance of winning the whole thing.
Old Nov 22, 2003 | 05:54 PM
  #322
Ruf-Racer's Avatar
Hey Chad,
I am just bugging Tyson to get going with the cage so he can run ORR next year. Agree his car has a good chance!
R
Old Nov 22, 2003 | 06:01 PM
  #323
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Roland,
Haven't gotten the cage yet. Won't do it until I get the specs and blessing from you and Carl.
Also, just read your post on the other site about you wanting me to get in touch with you regarding ORR. What is this charity run you were talking about, and when is it?
I am back in town tomorrow, will give you a call tomorrow or monday.
P.S. I'd rather be the dark horse in the event. Less pressure and less hype. My little blue car is just another Turbo with a loud exhaust.
Are you going to watch our little event?
Old Nov 22, 2003 | 06:23 PM
  #324
msindi's Avatar
C'mon Chad - try and make it - where there is a will there is a way...
I thought this shootout was ur idea anyway?? u've spent all this time and money....I think it would be much cooler if ur car shows up...
Old Nov 22, 2003 | 06:51 PM
  #325
sharkster's Avatar
Did somebody say Dark horse?? Come on now.. I'm bringing a lil' tiptronic grocery getter...
Old Nov 22, 2003 | 10:50 PM
  #326
sharkster's Avatar
ROFL!
In that case I better bring the wife's torque monster!
Old Dec 3, 2003 | 12:18 AM
  #327
cjv's Avatar
cjv
Moderator
quote cjv
" R,
I don't believe Tyson was ever a dark horse. I believe he has an excellent chance of winning the whole thing."
Old Dec 3, 2003 | 01:33 AM
  #328
J.Moss's Avatar
J.Moss is infamous around these parts
Originally posted by cjv
sticky,
Torque not hp is what usually bends rods. HP can cause problems in the higher rpm ranges. I understand the stock motor is somewhat safe to 7300 rpm's. I understand the 993 turbo rods started to encounter problems after 600 rwt. I have exceed that, but a little nervous about the test of time with the stock rods.
We are now taking a different approach. We are droping the torque to approximately 600 rwt, however instead of just peaking at about 4400 rpm's we are attempting to carry the 600 ft lbs through to redline. In other words a flatline 600 ft. lbs. of torque from approx. 3800 through 6800 rpm range.
The limitation is not defined by a number. More like how much pressure per cylinder event. A good point would be to imagine a motor that makes 500 foot lbs at 1000 rpms would put considerably more load on the rods than the same torque at 5000 rpms.
My experience in tuning VW/Audi engines is that having too much torque soon in the power band will essentially hydrolock a motor. Put bluntly, bend some expensive shi-ot.
This is why the really high powered cars with big turbos are less knock prone as the pressure per event is less. This can also put less stress on the rods.
I would be really interested in examining some failed engines to try and determine the actual cause of failure.
Jeff
Old Dec 3, 2003 | 07:11 AM
  #329
cjv's Avatar
cjv
Moderator
Jeff,
Based on your above explanation it sounds like we are on the right track by not starting the nitrous until after the peak torque has passed. It also does not hit at once as it has a programmer that pulses it on over a certain period. The above numbers are without the use of nitrous.
It also brings up another question about stress in the lower rpm's. I changed my gearing. The stock first gear is 3.818 and the second is 2.048. I have changed them all, but my question relates to first and second. I went to 3.167 for first and 1.938 for second. I had found, with my power the stock gears were useless. They just spinned the tires and were over in a blink. I guess the question is, in your opinion, how does this gear change effect the torque as it relates to pressure on the rods?
Old Dec 18, 2003 | 08:29 PM
  #330
cjv's Avatar
cjv
Moderator
I had removed my rear seat and seat belts several months ago. For over three months I have tried to find the part number for the part that covers the hole left when the retractible rear seat belt is removed. The stock part that comes off has a hole for the seat belt.
What I discovered is there is no part number. I removed the part on both a GT2 and GT3. What I found was Porsche covers the stock part (with the hole) in leather.
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
