Tuning/Modifications
Gearbox Modifications?
Old Dec 13, 2011 | 06:10 AM
siraff's Avatar
siraff is infamous around these parts
Hello. I'm new so go easy on me. I've done a quick search and come up with nothing apart from a lot of tiptronic threads. Basically I'm after some transaxle info - like what torque they can take (and at what rpm) and by how much this can be imporved. Also I would like to know how how much the gearing can be changed - in this case gearing it up so the revs come down.
Any info would be very welcome.
Simon.
Old Dec 21, 2011 | 07:26 AM
Tim941NYC's Avatar
tip or 6speed?
Old Dec 22, 2011 | 05:34 PM
siraff's Avatar
Originally Posted by Tim941NYC
tip or 6speed?
It can use either a 5 or 6 speed - both manual.
Old Dec 27, 2011 | 10:45 PM
Tim941NYC's Avatar
Gearing is anything you want. There are plenty of 996 turbos running 650 plus ft lbs of torque with no problem. 5&6spd turbo boxes will hold up the same.
Old Dec 28, 2011 | 06:55 AM
siraff's Avatar
I don't suppose you know how much more they can take do you? You see I'm thinking of using one behind a duramax 6.6TD in a kit car. Obviously that means I want the longest gearing I can find (or just gearing that gives around 200mph at around 3500rpm) but also the duramax makes 650lb of torque in standard trim which only gives 360hp. Really I want at least 550hp but that equates to around 850lb.
Old Dec 28, 2011 | 06:02 PM
Tim941NYC's Avatar
I think you will need to look for something else. When you overdrive like that the force that the torque puts on the gears, bearings, shafts and cases is more then just the 850lbs and 550hp. Maybe the ford gt trans?
Old Dec 30, 2011 | 06:56 AM
siraff's Avatar
Yeah I suppose it is asking a bit much. The other option I was playing with was to get a porsche turbo engine to go with the 'box. Only a couple of issues there - I don't know how bad they are to wire and I don't know how much they cost. I would presume they're pretty expensive? I wouldn't mind getting a blown one and rebuilding it but it's finding one...
Old Jan 13, 2012 | 06:52 AM
Tim941NYC's Avatar
Ebay. Wiring a standalone is not that bad. you can keep the vario cam and low/high lift intake with most units out there.
Old Feb 2, 2012 | 07:49 AM
fdjkas's Avatar
fdjkas is infamous around these parts
SlinginHoss
11
Oct 8, 2025 05:16 PM
embdenb
Sep 30, 2015 09:27 AM
