Wheels/Tires
Tire HELP
Old Mar 21, 2008 | 11:36 AM
YSITSMN's Avatar
YSITSMN is infamous around these parts
Tire HELP
I have been looking at every brand and make trying to find the best tire to fit on my RS4. I am looking to put a wider tire than the stock 255-35-19. I am looking for a 265 or even better a 275 with a 5mm spacer. I am having trouble finding a 19" tire in these sizes. The tire will be used for mostly daily driving with weekend track use. Who has suggestions.....
Old Mar 21, 2008 | 01:31 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
265/30/19 and 275/30/19 Pirelli Pzeros.
Old Mar 21, 2008 | 06:20 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Tire size calculator says 295/30-19, and you'll be w/in .2% speedo reading!
Old Mar 21, 2008 | 06:37 PM
But the RS4 is AWD and they use the same sizes up front and in the rear, and the 295 wont fit up front. I dont think they will in the back either
Old Mar 21, 2008 | 06:44 PM
Gcalo's Avatar
That's correct. I wasn't thinking of that!
Old Mar 23, 2008 | 03:47 PM
ahavams's Avatar
ahavams is infamous around these parts
The Bridgestone Potenza RE01R is an amazing dual purpose street/track tire. It's also priced very reasonably at $265 each from Tire Rack in the 275/30/19 size. It will be ~0.3" shorter diameter overall than the stock tires which won't be very noticeable.
Old Apr 1, 2008 | 12:14 PM
YSITSMN's Avatar
I saw that they make the Yoko and the Bridgstone in 275 30 and 35 profile. Do I need to run the lower profile tire if i go wider?? ANd I think that some one told me that I would need to run a 5mm spacer all around.
Old Apr 1, 2008 | 01:14 PM
RimsTrafficker's Avatar
RimsTrafficker is infamous around these parts
Curious..Are you looking for upgrade in handling or just the look of a more aggressive tire? I am an authorized Bridgestone dealer and Bridgestone makes a a 275/30/19 called the Potenza RE760 Sport w/ Uni-T, awesome tire..I have personal experience with these tires and let me tell you they stick! I even ship out..pm for price
Old Apr 1, 2008 | 01:16 PM
Oh and the Potenza RE01R I can beat tire rack price and do 257.00
Old Apr 1, 2008 | 02:25 PM
ahavams's Avatar
You should run the shorter tire size, 275/30/19 since it will give you a little more clearance and better acceleration. You may be able to fit the taller 275/35/19 but it will most likely rub since it's over 1/2" taller than the stock size tire.
Not sure about the spacers... I assume those are for additional clearance from the suspension when you run wider tires on the stock wheels but the cars I've run the 275/30/19 tires on all had aftermarket wheels so no spacers where needed.
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
oo7
Sep 10, 2015 08:08 AM
WheelB
Sep 3, 2015 10:26 AM
gabe325
911
Sep 2, 2015 08:10 PM
