GIAC vs Cobb - same car same day
Originally Posted by jmorgan911
Could you overlay the VBOX data between runs? I know it's like comparing apples to oranges but recently I ran my car at ATCO with 100 octane tune and 93 octane tune and ran nearly the exact same time and ET. Weird, I know, and I even posted that I couldn't explain why my times were so similar.
And I agree having the AP saves so much time and hassle not having to go to the dealer for every little thing. Think about it, your entire event was saved by the AP!
If I am not mistaken you were running pump gas in the cool morning and race gas in the hot afternoon. That might explain why your times didn't change. The DA was worse in the afternoon and the extra power generated by the race gas may have compensated for it. In either case your car was running like a champ that day. Still can't believe you had a 60 foot time in the 1.4's on one run. Just fantastic.
John:
So then a back to back comparison between different tunes isn't really going to answer any questions, correct? Seems like a few members have attempted this with no luck. This may explain why
I don't think there is a right or wrong answer and it ultimately is any consumers call on what they feel is the best value for their money and the best product for their use.
We all want to see our tuners/vendors do well for obvious reasons. If my tuner(s) do well, the amazing support I get will continue. My car will win. They will also not abandon my platform anytime soon. Plus, a few of the guys are great dudes on a personal level so it makes you want to see them succeed as well.
My $0.02
Vbox data is in! and it's very interesting to say the least.
I graphed the GIAC Stage 2+ pump tune run (red) against the Cobb Stage 3 100 octane tune (blue).
in the end, the Cobb tune won the mile by 85 feet or almost 6 car lengths.
you can clearly see the wheel slippage I got when it dropped into second gear on the GIAC run, which cost speed/time. my best estimate looking at the graph is that cost about 35 feet or 2.5 car lengths.
however, before that, you can see Cobb got off the line quicker as it was already pulling away before that.
however, the most interesting part I see is that you after recovering from the wheel spin, you can see GIAC closing the gap against the Cobb line the entire rest of the way.
what does this mean? it's clear the increased Cobb torque launches quicker, but perhaps this is showing the GIAC tune is stronger on the higher end?
unfortunately, it's only one run on each and I'm really bummed I wasn't running the GIAC race tune, so it doesn't mean a ton, but it was interesting to me nonetheless.
GIAC Stage 2+ Pump vs Cobb Stage 3 100 oct
¼ mi – 12.19@129.44 vs 11.41@132.36
½ mi – 18.39@159.89 vs 17.47@162.25
1mi – 28.62@188.8 vs 27.57@191.08
the second graph is the Cobb Stage 3 tune against the custom tune Mitch sent over.
you can clearly see the custom tune made a significant difference in time, but not really in speed. that seems weird to me since if I get there quicker, you think it should be faster also. perhaps the slight decrease in tail wind on the second run is what really hampered the speed.
¼ mi – 11.4@132.35 vs 11.25@132.69
½ mi – 17.47@162.25 vs 17.32@161.95
1 mi – 27.57@191.08 vs 27.44@190.43
so I've had the Cobb Stage 3 tune on my car for the last month.
I got several different tweaks from Mitch, who is always really responsive.
that said, I feel like the GIAC 2+ tune was much more drivable on a day to day basis. it felt like stock, just faster.
the Cobb tune jumps the boost really rapidly from about 6PSI to 14PSI which causes you to launch when you just press the accelerator down a little more. so then you let off the accelerator a little and it drops back down and you lose acceleration really fast and it just feels really jerky. Mitch was able to dial that down some, but it's still jumpy, which doesn't make for smooth daily driving, which is what I use the car for 99% of the time.
I'm going to get the new GIAC 2+ tune put back on my car soon and drive with it for a while to see if I'm imagining things, but I don't remember it doing anything like that.
I also want to compare the SOP benchmarks on launch and overall acceleration. at this point I've been driving the Cobb so long, I can't really remember the GIAC enough to compare other than the boost issue.
Originally Posted by unotaz
Very interesting. I noticed a similar drivability issue on my Cobb Stage 2 tune as well. When I'm cruising on the highway in 7th gear at 85mph, the throttle is very difficult to modulate and the boost would oscillate back and forth between 6psi to 12psi sometimes. Put simply, if I'm feathering the throttle to get some mild acceleration, the power comes on too strong and I need to back off the throttle, but the power goes down too much if I back off 100%. We need a new update please!
So I take it you guys are driving the car in normal mode using automatic shifting? I never go to 7th gear, even on the highway, it doesn't save any gas. I always keep the revs above 2500 by driving in manual mode with sport and so I never experience the things described here. I guess if you want to drive the car like a regular DD then you should probably go with Stage 1? I think Americanmade says his drives great at Stage 1. The beauty of the AP is how easy it is to change the map.
Just a thought.
Just a thought.
So I take it you guys are driving the car in normal mode using automatic shifting? I never go to 7th gear, even on the highway, it doesn't save any gas. I always keep the revs above 2500 by driving in manual mode with sport and so I never experience the things described here. I guess if you want to drive the car like regular DD then you should probably go with Stage 1? I think Americanmade says his drives great at Stage 1. The beauty of the AP is how easy it is to change the map.
Just a thought.
Just a thought.
Oh yes, I see you are driving on the highway in 7th gear which I don't do. I have found 7th gear to be unresponsive no matter what tune or not I have on the car. It was unresponsive when I bought the car on the way back from Dallas before I ever got a tune so I just stayed away from it. I don't think that has to do with the tune, I think it has to do with that being nothing more than a cruising gear.
