991 PSE Install - Definitive list of Parts and Prices
Old Dec 22, 2014 | 09:08 AM
  #31
wanderfalke's Avatar
wanderfalke is infamous around these parts
Originally Posted by plenum
E-12 Torx.
Thank you.
Old Dec 22, 2014 | 11:22 AM
  #32
does195's Avatar
does195 is infamous around these parts
Originally Posted by midwesterner
How much did your parts run you? Your attachment seems to suggest approx $400, but that can't be correct.
As stated, "Aftermarket Exhaust" I had my dealer install the AWE system, but wanted the option to keep in quiet in the neighborhood.
Old Dec 31, 2014 | 10:07 AM
  #33
I have a 2013 CS4 that had a standard exhaust. After using the part by part approach reusing my tailpipe tips ect. I have noticed the following -when engaging sport mode the PSE button automatically lights up. So I wonder if the valves would open without the PSE switch installed if one engages sport mode? My guess is no or it would have been covered here already.
Old Jan 1, 2015 | 01:08 PM
  #34
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
Yes, it should come on automatically.
When I got my X51 installed it came with PSE. Since I didn't have it before, I had no PSE button. The installation didn't come with the button either.
In normal mode the car is 'quiet'. If I hit the sport or sport plus, you automatically hear the volume change.
Old Jan 1, 2015 | 06:23 PM
  #35
To be clear when you are at idle(below 3500 rpms) and hit the sport button you can hear the exhaust emit a deeper tone? In my mind that makes the panel switch unnecessary. I was surprised to heard this because the side mufflers are not usually bypassed automatically until 3500 rpms.
Old Jan 2, 2015 | 09:30 PM
  #36
Chupacabra's Avatar
You are correct. In standard Jose without PSE activated the car will sound like 'wawawawa'. When you activate PSE it changes to a 'woowoowoo'. It's not a huge change but it does get louder.
I agree that the button is rather unnecessary. It really only works when in regular mode.
Old Jan 2, 2015 | 10:40 PM
  #37
Before I installed PSE the side mufflers were not bypassed automatically until 3500 rpms were reached. With the standard exhaust sport mode had no effect on the exhaust except it raised the idle rpms about 100 clicks. 2013 C4S
Old Jan 13, 2015 | 08:37 AM
  #38
C4S991's Avatar
C4S991 is infamous around these parts
I am starting this process with my dealer to see what I come up with.
I sent the parts list OP provided and will report back what they come back with. First pass, the quoted the PSE kit...
Hopefully I can get this done near the price OP paid!
Old Jan 13, 2015 | 09:15 AM
  #39
C4S991's Avatar
already catching some resistance due to the lack of replacement side mufflers. i realize that the parts list doesnt replace the sides and that OP has a working exhaust system, but are the side mufflers on an S the same as those in the PSE kit?
Old Jan 13, 2015 | 09:43 AM
  #40
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
The existing side mufflers on an S/4S are the same part number as those that come with the PSE kit. I would recommend having your dealer call Porsche of Rockville if they have any concerns. Earl was the mechanic that installed mine --- he did an awesome job and was very knowledgable.
Old Jan 13, 2015 | 10:19 AM
  #41
C4S991's Avatar
excellent thank you.
Old Jan 13, 2015 | 11:32 AM
  #42
C4S991's Avatar
My SA is reporting that both the S and 4S use the same side mufflers and they are 991 111 321 01 for left & 991 111 322 01 for right. He says that the Sport kit shows 991 111 325 01 for left & 991 111 326 01 for the right.
Old Jan 13, 2015 | 11:50 AM
  #43
911cv's Avatar
For all intents and purposes it is the same muffler. I didn't swap mine and neither have numerous other people on this forum. I would suggest having your SA call either Gina (SA) at Sonnen (she is the one that originally confirmed this for me) or Earl (Tech) at Porsche of Rockville. If you would like, PM me your email address and I can forward you the emails that Gina sent me regarding this topic.
Old Jan 13, 2015 | 11:58 AM
  #44
C4S991's Avatar
PM sent. thanks
Old Jan 14, 2015 | 10:36 AM
  #45
dphouse's Avatar
dphouse is infamous around these parts
By the way, the dealer had originally told me they would need the car for two days in case they ran into issues with programming. I got lucky that the car (even though did experience ecu programming delays) was ready for me one minute prior to closing.
Also, they had a promotion that reduced the labor slightly. I was originally quoted $975 for the install. In case someone decides to contact the dealer about the PSE install, I'd like you to have complete information.
Good luck guys.
PSE is amazing.
