Is this a boost leak?
Old Oct 4, 2007 | 01:12 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
On my way into work today, I jumped on the highway (no one really around), and punched it through 2nd and into 3rd gear. As I was nearing the last 1000 rpms or so of 3rd, the car was boosting 1.1 steady then dropped to .9 (felt the difference in pull too) and then climbed back up within a few hundred rpms to 1.1. I shifted into 4th, and the car stayed at a steady 1.1 with no hiccups...then decided to slow down since the exit was near.
My question then, is this a sign of a boost leak, bad plugs, or maybe just a fluke? It was a very evident feel, but didn't "hiccup" like when I had the old FR5 plugs. Thanks for any thoughts or insight.
Old Oct 4, 2007 | 03:06 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
bong - what did the hicup feel like?
Old Oct 5, 2007 | 08:48 AM
M3CAB's Avatar
Hey Chris, it really was not a hiccup, more of a flat spot feeling, like I released the pedal a little and depressed it again.
Old Oct 5, 2007 | 10:46 AM
seems like ur pulling timing and or the TB is shutting down.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 5, 2007 | 01:13 PM
M3CAB's Avatar
Hey Markski, I think you are right about it pulling timing. As for the TB shutdown, it is not going into limp mode at all. I will try to do duplicate it again tonight on the way home.
Thanks.
Old Jul 20, 2008 | 05:23 PM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
following
Old Jul 21, 2008 | 04:01 AM
revengerocket's Avatar
revengerocket is infamous around these parts
My car was doing that in all gears. Boost would drop in the midrange, then pick up as I neared redline. Replaced my plugs - problem solved.
Old Jul 21, 2008 | 09:47 AM
SpeedYellow's Avatar
SpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura about
Yup.... problem described above is ignition related not boost leak related.
This is what you get with a true boost leak:
Old Jul 21, 2008 | 11:01 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Old Jul 21, 2008 | 11:16 AM
Definitely in "Limp Mode"
awesomebang
Jul 5, 2017 08:48 PM
COBB Tuning
Jan 5, 2016 07:06 AM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
