ABS PSM Warning
Old Sep 29, 2008 | 09:04 PM
tom kerr's Avatar
Originally Posted by wross996TT
First...please get the codes....please...I bet on Tom on this one.
I did get the codes and it said front wheel sensor, replaced it and it still says the same thing that why we had to search further, and why I gave the rest of the algorhythm.
Old Sep 29, 2008 | 10:13 PM
Chris Green's Avatar
Chris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond repute
I fixed mine at last here is what I did, first I kept geting a code for front left wheel speed sensor, so I swapped the fronts and it stayed at the left so I knew it wasn't the sensor, only things left were ,wiring,abs unit or abs ring on axle. so I cleaned the ring still nothing next thing I ran a double 16ga wire from the wheel speed sensor direct to the abs box and wala its fixed!!! Reason I didn't do this a long time ago was every time I checked continuity it ohmed out fine, guess it was just weak in the harness or something. I just ordered a repair kit for the harness to fix it right.
Chris Green
Old Sep 30, 2008 | 11:07 AM
wross996TT's Avatar
Uh, Tom, I was addressing the OP....
Old Sep 30, 2008 | 01:03 PM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Ok had my oil sender unit fixed today. The oil gauge is working again. They also tested for my ABS and PSM problem I mentioned to them and car returned zero codes – nothing. They said it was probably some debris or water – did I just wash the car? HUH? Well haven’t had the error since then. Is debris really a possible or just dealer BS to get me off their backs?
Old Sep 30, 2008 | 02:58 PM
MikeR's Avatar
MikeR is infamous around these parts
Chris Green
Dealer(s) have done the same steps with my car, first harness, then sensors. Now it looks to be the abs control unit. Good thing you were able to stop on the harness, the control unit and other associated new parts are expensive.
To the OP, good to see your car is working again.
Old Apr 11, 2009 | 11:00 PM
jeff4774's Avatar
jeff4774 is infamous around these parts
anyway to test the MAF sensor to see if its bad?
randalldahme
Feb 19, 2016 03:56 PM
airbusdrvr
Dec 27, 2015 07:43 PM
vkvmd
Oct 5, 2015 02:04 PM
DYL 911
Oct 1, 2015 02:47 PM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
