fidenza lwfw with sprung hub disc problem
Old Nov 11, 2008 | 02:02 PM
kirk911tt's Avatar
kirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud of
I'm being told you can't run a sprung hub disc with a lwfw without machining to clear the bolts. Is this true?
Old Nov 11, 2008 | 03:12 PM
Mikelly's Avatar
I'm running the 964RS LWFW setup without any known need for machining anything to clear bolts...
Mike
Old Nov 11, 2008 | 03:25 PM
kirk911tt's Avatar
Mike,
is your disk sprung or rigid?
Old Nov 11, 2008 | 03:27 PM
kirk911tt's Avatar
I want to put the clutchmaster stg3 setup with the fibertough but wondering if a rigid disk with a lwfw will cause driveability problems.
Old Nov 11, 2008 | 08:54 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Just get the Clutchmaster LWFW.
Old Nov 12, 2008 | 03:20 PM
Mikelly's Avatar
My clutch disc is the sprung unit. I'd recommend the FiberTough application, and you'll be fine with clamp load, especially if you use the clutch masters fulcrum mod to the PP.
Mike
Old Nov 12, 2008 | 04:37 PM
Member
Mike, is the fulcrum mod standard by CM when you buy their fibertough sprung disc & PP or do you have to request it?
Old Nov 13, 2008 | 06:04 PM
Mikelly's Avatar
You request it with the Sachs 999PP.
Mike
the5
Oct 14, 2015 06:46 AM
Texas1
Sep 20, 2015 09:12 AM
Goonie
Sep 12, 2015 02:10 AM
mjdVantage
Sep 5, 2015 07:22 PM
