DIY Head Light Switch Remove and Replace
Old Jan 23, 2013 | 05:53 PM
  #61
Dan Babb's Avatar
Dan Babb is infamous around these parts
Nevermind. There is a release tab to get it off.
Found details here
http://www.pelicanparts.com/techarti...amp_Switch.htm
Old Aug 30, 2013 | 01:26 PM
  #62
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
Thank you to the OP and for keeping the pictures live since 2009! Super write-up. FYI, my Xenon headlights started acting up, only coming on occassionally until they finally gave out completely. Parking, tail, and fog lights continued to work fine. I didn't try cleaning the contacts, called Suncoast and got a new switch for $100 (local dealer wanted $175). It is about a 15min job very easy. The PN for the switch is 996-613-535-00 and don't be alarmed if the headlights don't come on after you complete the job, you might have forgotten to reconnect the battery or put the key in the ignition.
Old Nov 12, 2013 | 08:47 PM
  #63
dodger2233's Avatar
dodger2233 is infamous around these parts
Great pics and write up
Thanks for the write up!! I know I couldn't have done this without your write up. Very satisfying to do it myself instead of shelling out hundreds to a garage!! Thanks!!
Old Dec 8, 2013 | 08:21 AM
  #64
jpflip's Avatar
Just to show you the interior of the switch at fault. Here's some pictures of a switch that seems to be good from the outside but completely destroy inside…Thanks to Randal from Renntech for the pictures….
ID:	309227   Click image for larger version
ID:	309228   Click image for larger version
Name:	2013-12-08 08.59.45.jpg
ID:	309229   Click image for larger version
Name:	2013-12-08 08.59.19.jpg
Old Dec 8, 2013 | 08:32 AM
  #65
911TurboRules's Avatar
911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of
Wow! How does it get like that? Heat?
Old Dec 8, 2013 | 09:05 AM
  #66
jpflip's Avatar
Heat and bad type of plastic I guess.
Old Dec 19, 2013 | 12:42 PM
  #67
Blytha's Avatar
Blytha is infamous around these parts
Thumbs up
Thanks for the detailed description. Before going the whole hog and taking the switch out, I removed the switch **** and sprayed into the switch with contact cleaner, using some paper towel to prevent drips. I replaced the **** and rotated a good few times and it's worked! All without removing the switch
So I'd suggest giving this a try before removing the switch itself, took me ten minutes
I would not even have tried this without these instructions though. Thanks again.
Ant
Old Dec 26, 2013 | 02:06 PM
  #68
sdharmani's Avatar
sdharmani is infamous around these parts
I had the same issue.... main beam wouldn't come on without fiddling the switch. Just replaced it with a new one. $110 is worth the peace of mind ;-)
Thanks for the write up. I did manage to prey off the sticker accidentally - bummer. But was able to put it back on without an issue.
Old Feb 9, 2014 | 02:07 PM
  #69
laughing_guitar's Avatar
laughing_guitar is infamous around these partslaughing_guitar is infamous around these parts
Great to see that this thread is still reasonably active.
How are you guys getting the bezel off? This is step 7 from the instructions. It appears that mine is stuck and just won't come off. I'm ruining my leather trim in the process of trying to get it off .
Any tips?
Old Feb 9, 2014 | 02:19 PM
  #70
BMiller33's Avatar
IIRC there is a nut that has to be removed first over the stem.
Old Feb 9, 2014 | 02:24 PM
  #71
Yup. Got the nut off and the switch is disconnected. But, the actual bezel is stuck. Seems like you need to pry it off. I've tried that and I've also tried to push it out from behind, but I'm just damaging the trim right now. Any tips?
Old Feb 9, 2014 | 06:36 PM
  #72
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
it's been a few years since I did it but I think its just a matter of push/ pull...
Old Mar 12, 2014 | 07:22 PM
  #73
Empyreal's Avatar
Empyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to behold
People are using MAF cleaner. What about strict contact aerosol spray? Will that work, too?
Old Jul 25, 2014 | 09:22 PM
  #74
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
Big thank you!
No lights, to lights in 20 minutes!
Without this DIY, there is NO WAY, I would have pulled the vent hard enough to get access; I owe you a beer! KH
Old Nov 1, 2014 | 01:40 PM
  #75
Romans 1:16's Avatar
Romans 1:16 is just really niceRomans 1:16 is just really niceRomans 1:16 is just really niceRomans 1:16 is just really nice
Another BIG THANKS!!!
I just wanted to make a quick shout out to those who post the DIY threads that help us to save time and $$.
Just replaced the switch and now ready for the races tonight....oops, I mean hangin' out with other gear heads.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
