replacement DV
Old Jun 26, 2009 | 10:17 PM
kc2ab's Avatar
kc2ab is infamous around these parts
replacement DV
have a '03 x50 tip...stock...looking at intake,ecu and exhaust but want to get input on DV.... there's a few different ones out there and wandering which ones best or which ones to avoid.... which has the most correct settings/spring tension to correctly blow off without wasting boost pressure? i dont' have a prob with my stock yet but i figure i'll do it at the same time .... umw, agency, etc etc...pls help.
jimR
Old Jun 26, 2009 | 10:47 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
I think the popular opinion is that any of the aftermarket billet DVs are more reliable than the stock Bosch units. Some say that Bailey's are better as they claim that no routine maintenence is needed. Some say Forge are better because they can come with different tension springs and can be taken apart for routine cleaning and lubing. Some people say that many of the major brands all come from the same place, and are just "rebadged" for different vendors. People have reported problems with almost all types of DVs, and some people will swear by a specific brand.
My recommendation is to go with whichever type your tuner recommends (most tuners recommend billet type DVs, but some may recommend "upgraded" Bosch units). I would definitely change the F-hose to the silicone type while doing the DVs, as you are already there, to avoid issues with leaks from the stock rubber F-hose.
Old Jun 26, 2009 | 11:13 PM
Alpha's Avatar
Link to a thread showing a pic of a huge split in the stock F-hose: https://www.6speedonline.com/forums/...all-again.html
Old Jun 27, 2009 | 11:56 PM
kc2ab's Avatar
DV issue
ok...thanks for ur reply. i read some thread on what u r talking about....
now, the factory bosch unit is NOT serviceable? where as forge and some are serviceable in that you can take it out and clean and regrease it, from what i see...
then,....does the factory one fail 'cause we don't clean /service it? on the billet ones, how often are we supposed to service these?
my 03 x50 tip is getting .9 bar currently in stock mode....
thinking of doing the ecu and airbox/exhaust...so will do DV /f hose at the same time for sure and hence am collecting info. thanks for your replies.
jim R
Old Jun 28, 2009 | 12:13 AM
oak's Avatar
oak
not all billets dvs are the same.it's a job you want to do only once. get the baileys dvs. lifetime warranty.
Old Jun 28, 2009 | 02:13 AM
Alpha's Avatar
The stock DVs are a "diaphragm" type of valve, different design than the billet DVs. The stock DVs fail most commonly from tears of the diaphragm, allowing boost leak.
Everyone has their opinion as to which type of DV is best. There are pros and cons of each type.
Old Jun 28, 2009 | 10:52 AM
RedlineMotorworks's Avatar
RedlineMotorworks is infamous around these partsRedlineMotorworks is infamous around these parts
Alpha is correct. The OEM DV fails when under higher boost because the diaphragm is not designed to support that kind of pressure and tears.
A great upgrade would be the Agency Power DV + F-Hose. We have this package for under $350.
Old Jun 28, 2009 | 02:04 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
No diff in performance when I installed mine. Just good looks. I have the Forge units.
Old Jun 28, 2009 | 03:06 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
have two forge units, they can be yours pm me, i took off because they were not loud enough, u can hear them with stock piping but not with the evo pipingto the turbos
Jun 10, 2017 07:45 PM
henryr
Sep 24, 2015 08:22 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 24, 2015 09:29 AM
Jeff1smith
Aug 19, 2015 09:41 PM
