starting car without using clutch
Old Aug 27, 2009 | 02:43 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i wanted to be able to start my car without having to depress the clutch, its very simple and only takes a few minutes
you will need a flashlight to see what you are doing, first locate the clutch switch, if you follow the clutch pedal up you will see a small light gray plastic block with 2 brownish wires attached to it
they are attached using female crimps, i then cut the end of male crimp i had and used it to attach the two female ends to each other, i did this becuase if ever i want to reverse this mod it will quick simple and look like it was never touched
once they are attached to each other i tucked them up out of the way, my car will now start without depressing the clutch at all
disclaimer - if you do not remember if you left your car in gear or not you should check before starting the car otherwise you and your car may become severely traumatized and/or damaged, if you are not capable of remembering or checking then you should not do this mod, and probably should not be driving any car period
Old Aug 27, 2009 | 03:10 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
How do you like your metal pedals?
Old Aug 27, 2009 | 03:12 PM
luva966tt's Avatar
luva966tt is infamous around these partsluva966tt is infamous around these parts
???? wtf
Old Aug 27, 2009 | 03:44 PM
buzzm's Avatar
Originally Posted by luva966tt
???? wtf
in english please
Old Aug 27, 2009 | 03:45 PM
buzzm's Avatar
i love them, a lot of people on here have them, pretty easy installation, you only need some basic tools
Old Aug 27, 2009 | 05:23 PM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
I'd reconsider if anyone else ever starts your car. I've seen too many idiots start a car while in gear, and stall into whatever you're parked next to. (The first time was a brand new 993 coupe right into a pole. It happened when I worked at a dealer in high school in '95, and the guy tried to pin it on me for leaving it in 2nd.)
Old Aug 27, 2009 | 05:58 PM
buzzm's Avatar
no-one else starts my car
in england no-one ever leaves a car in gear unless you are parked on a steep hill, theres no point, thats what the hand break (safety break) is for and i dont remember any car in england ever needing the clutch to be depressed in order to start the car so this mod makes sense for me and proably will for other english people
i'm not saying everyone should do this mod, i'm just explaining how it can be done if you want to do it
Old Aug 27, 2009 | 06:19 PM
phillym5's Avatar
phillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to behold
I just did mine....
It took 5 minutes.
Very convenient.... thanks.
Old Aug 27, 2009 | 08:18 PM
'02996ttx50's Avatar
this is great info. having to depress the clutch to start is an incredible annoyance and just feels plain "wrong". thanks for posting.
Old Aug 27, 2009 | 08:25 PM
function12's Avatar
I guess this could also lead to a remote(fob) start install. Be nice to cool down or heat up the car before you got in.
Old Aug 27, 2009 | 08:38 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
You can also program it out of the ECU
Old Aug 27, 2009 | 08:48 PM
mdd's Avatar
mdd
mdd is infamous around these parts
I suspect your cruise control will not work after this mod is done. In a normally wired car, pushing the clutch pedal will disable cruise control.
Old Apr 16, 2010 | 10:45 AM
Bankai's Avatar
Bankai is infamous around these partsBankai is infamous around these partsBankai is infamous around these partsBankai is infamous around these parts
Anyone else have feedback on this mod? Planning to do it as I suspect my clutch switch is going out....AGAIN
Old Apr 16, 2010 | 10:57 AM
my friend just installed the Viper 5902 Alarm and remote start for me. being able to start the car a minute or 2 before i leave is very convenient.
we did put in a kill switch for remote start in case the car goes in for service.
#TeamAIM
Old Apr 16, 2010 | 03:41 PM
anikzad's Avatar
anikzad is a name known to allanikzad is a name known to allanikzad is a name known to allanikzad is a name known to allanikzad is a name known to allanikzad is a name known to all
Is there a mechanical advantage or disadvantage to starting the car without pressing the clutch?
