Blew my HEADGASKET :(
Old Dec 18, 2009 | 09:25 PM
  #61
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
are you gonna retorque it after heat cycle?
Old Dec 18, 2009 | 09:59 PM
  #62
Turbo Fanatic's Avatar
Good luck. I hope it comes together quickly.
Originally Posted by dgreen78
No, the builder told me that the Evo studs are the stuff and no need to O-ring. I am hoping they perform like they are hyped up to be and dont have any issues down the road like the ARP studs have had.
Old Dec 18, 2009 | 10:09 PM
  #63
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Don
Sorry I missed your call, I was at a dinner party. Ill call you tommorrow. I have a set of liner, we can talk about a price tommorrow.
Jag
PS...I want to see pics of the HG. Pics of mine are on my thread.
Old Dec 18, 2009 | 10:14 PM
  #64
jags911tt's Avatar
I dont think Alex will.....unless Don says he has to have it done.
Old Dec 19, 2009 | 12:08 AM
  #65
BLKMGK's Avatar
Exclamation
Originally Posted by Kevin
<snip>
If you are running a H20/Meth kit to provide fuel enrichment or octane/anti detonation you are risking your engine. You are relying on the methanol to get into EACH cylinder. What happens if we don't have a even distribution of meth and we lean out one cylinder.. The ECU will not correct for that "hole" The widebands will correct one bank to each other.. Yes, it will see the knock and retard that cylinder but it's a little to late.
<snip>
Are you SURE about this? (emphasis mine) These engines do not correct cylinder to cylinder? If so my 1988 Mustang was further advanced. Sorry but I think you're mistaken here. If this were the case you wouldn't see individual cylinder trims occurring in the ECU. It's quite possible for an ECU to correct per cylinder with an O2 in the collector and I'd be dumbfounded if Porsche wasn't doing that in these OBD-II cars...
Old Dec 19, 2009 | 12:36 AM
  #66
BLKMGK's Avatar
With this ECU it is bank to bank.. Knock is retarded per cylinder.. When you bench flow test the intake manifold (basically the same intake since 1992) You will find that certain cylinders are "favored".... When you turn it into a wet manifold the dynamics change.. You better make sure that the methanol is getting down each intake equally..
Almost any intake manifold is going to have cylinders that are leaner than others. For the ECU to not be correcting per cylinder just doesn't sound right C'mon the EECIV from FORD did it many years ago and the Porsche is way more sophisticated, this makes no sense. Heck the Ford didn't even have a knock sensor on the V8s Very scary if this is true.
Old Dec 19, 2009 | 08:36 AM
  #67
Divexxtreme's Avatar
And I know it sounds unlikely that the gasket would leak with no coolant loss but the fact is it did. I have built several motors myself and have never seen this before either.
A little history for those that aren't aware, but a couple of years ago ARP had released a bad batch of head studs to the market. Looks like Don unfortunately had them on his car.
In a related story, Protomotive ended up unknowingly using a set of those bad studs on my buddy's 3.8L build. After he got the car home, he blew his head gasket at only 1.2 BAR. Guess what? No coolant leaks. Dry as a f'ing bone. But the sound was obvious, as was his power loss. Proto repaired his motor at thier expense for something that wasn't even their fault. Different studs were installed and now 2+ years later, the car is 100% rock solid at 900+ rwhp. It's driven 4-5 times per week.
Anyway, as Kevin said earlier, yes...these cars can and do blow head gaskets without leaking any coolant. I've seen it with my own eyes.
Old Dec 19, 2009 | 10:21 AM
  #68
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
Even if there is correction per cylinder it will not be quick enough always.. Also the correction only goes so far.. If there is an issue out of the range of correction then your done again.. I don't know enough about the Factory Ecu of the 996 but my M5 which has individual cylinder mapping and one of the most state of the art ecus melted only 1 plug 1 time.. It didn't hurt the motor luckily.. We were hitting it pretty hard on a very cold night with the spray..
Mike
Old Dec 19, 2009 | 10:46 AM
  #69
BLKMGK's Avatar
Correct, it depends on knowing the distance from plug to O2 sensor in order to know which pulse is being read. High speed RPMs, moving the O2 (stupid), and sensor speed can all play into this. But the O2 on my Ford wasn't even a W/B and it had corrections. I'm pretty sure it had it anyway.
Frankly anything OBD-II sure as heck should have it. In any case it's not something you lean on any more than you would a knock sensor.
Old Dec 19, 2009 | 11:36 AM
  #70
jags911tt's Avatar
Scott
Dons engine is stock.
Old Dec 19, 2009 | 01:38 PM
  #71
Oops! Sorry about that! Got him confused with another guy on the forum...
My primary point was that these cars can blow headgaskets without leaking any coolant. This is the second car I've seen/heard of this happening to.
Thank you for the correction, Jags.
Old Dec 19, 2009 | 01:47 PM
  #72
jags911tt's Avatar
No problem Scott. When my HG blew the second time it was like a coolant hose had blown - coolant just pouring out
Old Dec 19, 2009 | 01:52 PM
  #73
Swole Powell's Avatar
Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !
I would have done a leak down before pulling the motor Don, its not that hard. Sorry to hear!
Old Dec 19, 2009 | 02:10 PM
  #74
heavychevy's Avatar
I never claimed the 996TT is less suited than those other cars. I'm saying a dedicated Porsche road-racer like yourself would prefer a GT3 or GT3RS over a TT. I don't see why that's such a strange idea.
I'm done with the rest of that but I couldn't leave this one alone. I'm sure glad you know me well enough to know what I want better than I do. I'm sure Tom Kerr, 1BadGT2, Stevo, GT2RSR, Al Norton and the tons of other guys that have built dedicated track car turbos will be sure to go start from scratch in GT3's.
Stick with what you know, and the road course isn't it.
Old Dec 19, 2009 | 02:31 PM
  #75
I wasn't claiming to be an expert.
I do know that Porsche specifically designed the GT3 and GT3RS to be street-legal track cars, so it seems obvious to me it would be a better choice for that purpose. I'd venture to guess that a lot of GT3 owners would agree with me on that point.
But if people want to spend the time, money and effort modifying a TT to be a dedicated road-course car, instead of simply buying a more purpose-built car like a GT3 or GT3RS, that's obviously their prerogative.
I'm simply saying that that's not what I would personally do, were I ever to get the itch to play around on road-courses. But you're the expert!
