Plenum/TB install 996TT
Old May 26, 2010 | 06:50 AM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
For those who have installed Plenums/TB's on their 996TT, can you do the job by lowering the motor w/o dropping it? Also, does the factory Y Pipe need to be altered in anyway? And is there a certain Throttle body I should buy?
Old May 26, 2010 | 07:25 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
my experience is with AP's product. It is possible to install with engine lowered, but not an easy job. I believe the OEM Y mount/bracket does need to be altered to fit the OEM Y. I used the AP Y so can't comment on details here. few members here have however and have posted relevant info, should be easy to find in a search.
Old May 26, 2010 | 08:18 AM
RickEager's Avatar
Was this mod worth the effort and what did you see in terms of HP/TQ gains... or your best guess???
Old May 26, 2010 | 08:45 AM
MBailey's Avatar
I did this mod with the IPD 75mm with a 75mm TB. My gains were noticable (3-5% increase) in the mid and high range. My wrench installed it without lowering the engine but its much easier if you lower it some. It is a very worthwhile mod. To reattach the Y-pipe with a typical coupler you will need to modify the base of the Y to the same diameter of the plenum/TB. Vivid has some couplers that increase/decrease the diameter so you could potentially use the standard Y-pipe if you could find the right coupler.
Old May 26, 2010 | 09:05 AM
John@SpeedTech's Avatar
I have done it several times without lowering the motor. The OEM boot will stretch to 75mm, but it's a pain...
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old May 26, 2010 | 09:42 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Im selling my evo setup (larger TB and modified ypipe) I am also selling my ipd plenum. Ill give you a great price. pm me.
Jag
Old May 26, 2010 | 10:00 AM
RickEager's Avatar
Jag
PM'd. But just doing my homework.
Old May 26, 2010 | 10:16 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
If you are doing 70mm, I believe the OEM TB will fit. If you are doing 75mm, you'll need a bigger TB. The OEM Ypipe may fit, but why not getting the bigger one and call it a day in that area?
Old May 26, 2010 | 10:27 AM
RickEager's Avatar
No mod needed to the stock y pipe?
Old May 26, 2010 | 12:14 PM
MBailey's Avatar
Yes, that is what he is saying.
Old May 26, 2010 | 12:38 PM
RickEager's Avatar
Cool!
Old May 26, 2010 | 01:42 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Get 75mm. Bigger than 70mm.
I did it with lower engine. Way easier. You will thank yourself.
If your engine is stock, it takes less than 5 min to lower engine. (Only 2 nuts)
Old May 26, 2010 | 01:48 PM
aroonkl's Avatar
Do Y-pipe the same time. Stock y-pipe is pretty small. If you increase size/flow of plenum and TB but have small section at stock y-pipe, what is the point? I think John/speedtech has special price running on y-pipe.
Old May 26, 2010 | 03:09 PM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Old May 26, 2010 | 03:55 PM
jags911tt's Avatar
For some weird reason Im not getting pms in my inbox. Email me at jagsm3@yahoo.com or call me at 253 332 4879
takenotes996tt
New Member Introductions
Sep 3, 2015 10:12 AM
bmwtmx
Aug 26, 2015 07:26 AM
John@SpeedTech
Aug 23, 2015 12:07 AM
