Is this too tight?
Old Nov 15, 2010 | 09:30 PM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Is this too tight?
Looking at a set of Victor Eqipment wheels with below specs.
Front 18x8" = ET 45
Rear 18x11"= ET 25
Running 225 in the front and 295 rear.
Will they fit a 996tt?
Thanks,
JE
Old Nov 15, 2010 | 09:32 PM
Turbo Fanatic's Avatar
Yes fits great. Roll the rear fenders = required
It's about as flush and sexy as possible
Old Nov 15, 2010 | 11:21 PM
Adam D's Avatar
Adam D is infamous around these parts
Whats the widest you can go at the back on a stock 996 turbo?
Old Nov 16, 2010 | 08:20 AM
I have ET35 rear on a 19x12 wheel and its flush. I rolled my fenders.
I think ET25 on 18x11 is definetly doable. Rolling fenders will be a must in the rear.
Front is good.
#TeamAIM
Old Nov 16, 2010 | 08:40 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
I found this offset calculator very helpful when selecting offsets?
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.discounttiredirect.com/di...gle%2BNational
Old Nov 16, 2010 | 10:32 AM
MartinF's Avatar
MartinF is infamous around these parts
i the question just under your avatar, so my first answer was : definitely
Old Nov 16, 2010 | 10:56 AM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
I think thats what I am running. I need to roll my rears.s On big dips, I hear it rub but have no visible impact.
Old Nov 17, 2010 | 06:50 PM
Mr. C4's Avatar
I used to run my stock wheels in the rear (11" ET 45) together with a 20mm spacer and they would protrude outside of the wheel arches and it did not look nice. I had the spacers machined down to 14mm and it looks great. Correct me if I'm wrong but isn't a 11" ET 45 wheel with a 20mm spacer the same as a 11" ET25 wheel? As a result I would end up with the same look as the stock wheels with a 20mm spacer...........
@ 2muchtime, yes I have seen that offset calculator.
Old Nov 18, 2010 | 07:33 AM
2muchtime's Avatar
Front is good.
FWIW I'm running 18 x 12 with 26 offset and they fit flush with the outside fender. Mine is not yet lowered so there is no rubbing issues..yet
randalldahme
Feb 19, 2016 03:56 PM
1gr8e39
Oct 1, 2015 04:07 PM
Wheeler
Sep 22, 2015 08:02 PM
BLKMGK
Sep 19, 2015 03:51 PM
