Laguna Seca Setup?
Old Dec 21, 2010 | 02:09 PM
uurfantasy's Avatar
uurfantasy has a spectacular aura aboutuurfantasy has a spectacular aura aboutuurfantasy has a spectacular aura about
Originally Posted by 80shilling
In terms of compression and rebound.. Laguna is fairly smooth, so crank your compression down to 2-3 from full hard in the front and rear.. Set your rebound at 3-4 from full hard.
On the PSS9's, isn't there only dial for compression/rebound? So whatever I set the compression/rebound to will be the same since there is only one dial for both?
Old Dec 21, 2010 | 02:11 PM
uurfantasy's Avatar
Originally Posted by heavychevy
Make sure get that toe issue fixed first. There is nothing like your car trying to make a left turn at WOT going over 100 mph. Mine tried it and Road Atlanta which is much like Laguna, not very forgiving.
If he aligns it, and it's still swerving all over the road, tell him he needs to do it better. I had a guy try to fix my car at the track with smart strings and it didn't work, car still going every which way.
You should not have to buy anything for your car to go in a straight line over 100mph.
I will have a lengthy chat with the alignment guy. Thanks!
Old Dec 21, 2010 | 02:17 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
If you need a good alignment shop let me know. He is the ****z.
Old Dec 21, 2010 | 02:22 PM
uurfantasy's Avatar
The shop I used, G12 (Sacramento), is a knowledgable guy, I just think he was a little confused.
I just spoke with him on the phone and he said he remembered me saying I wanted good tire life on my tires so he kept the settings accordingly.
*Now I said, I just want the left,right bucking gone upon hard acceleration and he said he knows what to do*
But what shop did you have in mind?
Old Dec 22, 2010 | 12:16 PM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Seriously, don't let your guy give you what he thinks will work.. Tell him what you want.... The settings I gave you will work.. trust me on this..
In terms of your shocks, I forgot that they do not have separate circuits.. I would crank them down to 2 from full hard (make sure you absolutely know which way is hard and which way is soft on those adjusters)...
wrs
Nov 17, 2016 06:53 AM
COBB Tuning
Jan 5, 2016 07:06 AM
shifter_
Sep 30, 2015 04:00 PM
PBass
Sep 29, 2015 10:28 AM
BauerR
Sep 28, 2015 11:36 AM
