First Trans Oil Change - Worry?
Old Jan 19, 2011 | 04:06 PM
Slider's Avatar
This is my first transmission oil change (107,000 Klm). There are metal shavings on my oil drain plug (see below). Everything seems to be working properly - no vibration or noise - should I be worried?
Old Jan 19, 2011 | 04:17 PM
djantlive's Avatar
i wouldn't worry. seems a little more but then you are changing it with 60k miles. is that the normal interval?
Old Jan 19, 2011 | 04:21 PM
Slider's Avatar
The maintenance schedule says 144,000 Km (90,000 mi).
Old Jan 19, 2011 | 06:39 PM
bk doc's Avatar
bk doc is infamous around these parts
Who is doing your mechanical work? I've been very fortunate to deal with an amazing place in Victoria. Let me know if you're interested. Unfortunately, I don't have enough posts to respond to anything you direct to me directly you..
Old Jan 19, 2011 | 07:18 PM
Slider's Avatar
You should post the name right here for everyone to see so it's there when someone does a search some time in the future...
I'm always interested in hearing about potential places to turn when I need help. Right now I do all the work myself, but sooner or later I'm going to need to do something that exceeds my comfort zone (maybe?!)
Old Jan 19, 2011 | 07:45 PM
bk doc's Avatar
Progressive Motorsports on Burnside are the people of choice. Troy is very fair in his pricing, and his head mechanic Jason is brilliant. I never have had an issue with anything they've done on my Porsches or my AC Cobra....
Old Jan 19, 2011 | 07:55 PM
Slider's Avatar
Yes, I know the place. Nice clean shop - looks very professional - thanks for the tip!
Old Jan 19, 2011 | 08:33 PM
djantlive's Avatar
wow, 90k miles for transmission. my gallardo is 15k miles!
Old Jan 19, 2011 | 11:13 PM
Slider's Avatar
If I had a mess that that after 15K - then I'd be worried!
Old Jan 25, 2011 | 10:50 PM
triplej's Avatar
triplej is infamous around these parts
I had the same metal filings on my plug at 60,000Kms I was told it was most likely from the dog teeth on 2nd gear. I now have 2nd gear popout. More details in this link : https://www.6speedonline.com/forums/...-grinding.html
Having said all that if you dont experience any problems, there's no problems!
Old Jan 26, 2011 | 11:39 AM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
After 60k miles, I wouldn't worry about that amount. Like another member said, if you were at 15-20k, it'd be an issue. If you haven't experienced any issues, then I'd forget about it and just know that it's cleaned out now and you're ready to rock another 60k. The plugs are designed to catch those bits just for that reason and it seems that yours if functioning just as it should be. Its normal wear and tear. You're good to go.
Great pics by the way!
Old Jan 26, 2011 | 03:35 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
That little bit seems normal for the interval your changing the fluid at.
Old Jan 26, 2011 | 04:47 PM
Slider's Avatar
Thanks for the tips - there has been no trouble shifting although changing the oil has made everything MUCH smoother!
Old Jan 26, 2011 | 06:44 PM
Yep...I'm taking mine in for the big 30k mile service in the next few months... can't wait to see the differences I feel. For $1500, I had better feel something .
Old Jan 27, 2011 | 12:24 AM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
Made it much smoother? You just encouraged me to change the transmission oil in my BMW.
4ocious
Sep 1, 2015 06:44 AM
hacellular
Aug 31, 2015 08:34 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
