Starting/battery issue
Old Feb 10, 2011 | 06:57 AM
deckman's Avatar
My car won't start. The day before it was fine. I turned the key, it cranked once then did the loud clicking. I attached jumper cables and still got clicking then the warning messages started cascading, the window dropped a bit and didn't return to its normal position.
The car is pretty new to me, and the previous owner bought a new battery in December 09. Should I assume the battery is the culprit and replace it?
Old Feb 10, 2011 | 10:18 AM
djantlive's Avatar
Does the car have electrical power? Do any lights (headlight, interior lights) look dim? Does the power window roll up slow now?
Did you jump the car with another full size car? Or was it with a small compact car? You need to rev the engine on the other car to give enough juice. Be careful about connections or you may fry your electronics.
If you have a multi-meter, measuring the voltage of your battery would be a good idea.
Other culprits could be loose battery cable, failing alternator or starter, failing ignition pack.
Old Feb 10, 2011 | 11:06 AM
Slider's Avatar
+1 - What he said. And... If you hear clicking while jump-starting the car, you are not properly connected. Wiggle the connectors until you get a good connection before trying to start the car. You will know you have a good connection when the lights on the "working" car dim and stay dim as you wiggle the connectors.
Old Feb 10, 2011 | 12:26 PM
deckman's Avatar
We'll see. I just bought another battery, the other was dead and wouldn't hold a charge. It just seems odd the previous one lasted just over a year. I'll install it later this afternoon.
Old Feb 10, 2011 | 04:26 PM
deckman's Avatar
I replaced the battery and it looked like the volt meter was dropping after the car was started. I went out and got a volt meter to measure it. With the ignition off it read 12.53 volts. I started it and started measuring, but it was dropping, and quickly. In under a minute it was under 12.
So this means it's either the alternator, voltage regulator, or the pulley? If there is any way to diagnose these without just buying replacements and seeing which one fixes it?
Old Feb 10, 2011 | 04:52 PM
naptownmike's Avatar
naptownmike is infamous around these parts
I had the same problem last spring turned out to be the alternator.
Old Feb 10, 2011 | 05:18 PM
Slider's Avatar
Well, you were going to need a battery anyway. If the pulley is spinning and the belt is on the pulley, it's not those two. So, you're left with alternator or voltage regulator - it's unlikely to be the voltage regulator so my bet is on the alternator. They are known to fail in just this way. I have not seen a lot of posts where the voltage regulator has gone bad.
Old Feb 10, 2011 | 05:38 PM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
I had the same problem last month and I had to replace my alternator (I think you too), I assume your previous battery was still good.
When the alternator goes bad the car's electronics are only drawing current from the battery and the alternator isn't charging the battery back so that's why it drops quickly.
With the engine started and a good alternator you're suppose to read HIGHER voltage than when the ignition is off.
Let me warn you, an alternator from the dealer is about $1400. Get one from eBay or online, it's a Bosch model AL0700X, don't worry about getting an 'OEM style' one and not original Bosch. Get a new regulator with it.
Old Feb 11, 2011 | 04:29 AM
Tim941NYC's Avatar
If the car sits for long periods with out being driven the battery will go bad quite quickly. Unless you use a battery tender or disconnect the battery.
Old Feb 11, 2011 | 07:00 AM
deckman's Avatar
So this alternator on ebay should work?
Old Feb 11, 2011 | 07:25 AM
jpflip's Avatar
Be careful with compatibility, this one doesn't work.... If I enter 2002, porsche, 911, turbo it say's "This part doesn't fit the vehicle you entered." Plus you have to be careful with the clutch and pulley assembly....
Old Feb 11, 2011 | 07:38 AM
deckman's Avatar
But it's the part# TPHSS said to use. I'll call them and do a bit more research. I want to get one ordered today so I can get it fairly quickly. I found a great DIY article and will remove the existing one this weekend.
Old Feb 11, 2011 | 08:35 AM
jpflip's Avatar
Let me know if it works because I am doing the same research and I am totally confused now. Some used 150 amps and others 120 amps. Some come with the pulley some without. There is also mention about with or without automatic transmission....With the part#997 603 012 01 and a search on ebay I got this one: http://shop.ebay.com/?_from=R40&_trk...All-Categories
Another DIY here : https://www.6speedonline.com/forums/...e-replace.html
Old Feb 11, 2011 | 09:14 AM
tphss's Avatar
deckman, don't beat yourself, get this one http://cgi.ebay.com/ebaymotors/NEW-PORSCHE-911-966-BOXSTER-986-ALTERNATOR-TURBO-97-04-_W0QQcmdZViewItemQQhashZitem45f4d49f03QQitemZ30046 0318467QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
That's the one I got, comes with the regulator and it's a quality product.
Old Feb 11, 2011 | 09:25 AM
jpflip's Avatar
Originally Posted by tphss
120 amps ?????
