Fender liners
Old Feb 21, 2011 | 06:29 PM
sunir's Avatar
Fender liners
I am contemplating replacing all the fender liners for '02 996TT ...do you think there is any difference between the turbo and the 996 GT2 liners? I think the front of the 2 peice liners on the front of the car are different, any adavantage in gettign the GT2 front liners? I talked to a dealer today that said that the GT2 front liners had slats for some sort of cooling duct...besides that the GT2 front liners cost a bit more than the standard turbo's front wheel liners...I think the rear half of the fronst are the same and the rear 2 peice linders are the same on both cars?? right?
Also running the 996TT front bumper would I Be able to fit the GT2 liners...
is it worth considering, or should I just stick with the factory 996TT liners
Old Feb 21, 2011 | 06:44 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
gt2 liners have more room and only cost like 15 dollars more I believe
Old Feb 21, 2011 | 09:44 PM
wross996TT's Avatar
unless you have the ducts from a techart or similar front bumper, the extra duct work on the gt2 liners are worthless...i would stick with the stock liners.
Old Feb 21, 2011 | 10:01 PM
sunir's Avatar
was told that the extra vents/slats on the gt2 liners work with the gt2 ducting from the gt2 bumper I guess...dunno if the turbo has that ducting since the bumpers are different...I thought the slats were to pull more air thru the radiators but looks like that's not the case...what's this about the gt2 liner having more room..I guess for larger tires? would be good for 245/18" track tires I suppose? any thoughts?
Old Feb 22, 2011 | 05:19 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
May I ask where are you going to buy those GT2 fender liners?
Old Feb 22, 2011 | 05:23 AM
rosesplus's Avatar
rosesplus is infamous around these parts
I'd love to know if the GT2liners allow for more wheel/tire room. I need to replace one and I'm running 235's on the front which brush the existing (cracked ) liner on full lock.
Old Feb 22, 2011 | 05:45 AM
Tim941NYC's Avatar
The gt2 front liner redirects the air flow out of the radiators to blow on the backside of the brakes and out the wheel. Turbo liner just dumps the air out. no direction. The rear lower rear liner and bracket (mounts to the intercooler bracket) give more room for the 12 inch rim to fit and not rub.
Old Feb 22, 2011 | 06:26 AM
rosesplus's Avatar
Tim are you saying the rear GT2 liners offer more wheel room but the front GT2's liners don't? My issue is with front drivers side liner, I run 315's on the rear without any rubbing issues. I have to replace the front liner and I'm trying to work out if I might be better ordering the GT2 liner. Thanks Mark
Old Feb 22, 2011 | 07:04 AM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
It depends what bumper you have. 996tt direct air out the radiators to blow out the bottom of the bumper and the wheel well is pretty sealed up. GT2's are sealed up from the bottom so like Tim said, they direct air flow out of the radiators to blow on the backside of the brakes and out the wheel.
Old Feb 22, 2011 | 12:28 PM
sunir's Avatar
So is there any advantage or can you run the GT2 front front liner for (1) better air to the brakes (or would you need the GT2 bumper cover and extra parts for this)? Also will the Gt2 front liner fit onto the 996TT bumper and offer a bit more front clearance with slightly wider tires?
(2) run the GT2 rear rear liner for the extra tire room out back? Will this bolt right up or are there extra parts (brackets, hardware etc..) needed to make this work?
(3) I know that the front rear liner are the same between the 996TT and the GT2....I am assuming that the rear front liners are the same also...am I right?
Just looking at the best solution for wheel liners, since I am replacing them anyway want to do it with the best options without breaking the bank or having to replace them later...what are your thoughts guys?
Old Feb 22, 2011 | 11:33 PM
Zippy's Avatar
I bought a set of Sportec Front cooling ducts from Kevin at UMW. They work great and direct air to the rotors. I can squeeze the 245s up front. I think looking into the GT2 rear fender liners would be a good replacement for the rears (I have 335s).
Old Feb 23, 2011 | 02:12 PM
sunir's Avatar
would you happen to have a pic of these? would like to see them...UMW doesn't seem to have a pic on their site or a cost...how much were they?
I assume that they work with the 996TT front half of the front wheel liners?
Old Feb 24, 2011 | 12:01 AM
Zippy's Avatar
I see you found a picture in an old thread. They are high quality. There's a 4"(?) ducting that moves air directly to the front rotors. If I remember correctly, they were quite expensive.
adnanm3
Oct 25, 2016 08:38 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
jdubbya
Sep 28, 2015 04:58 PM
