Decent brake upgrade options?
Old May 3, 2011 | 04:46 AM
H8T WP's Avatar
H8T WP is infamous around these parts
I know there are probably thousands of threads about this but im desperate to just get some parts today...
I want to know for the standard 4 pot brakes on the turbo what pads , lines and fluid would work best
that is all. thank you
Old May 3, 2011 | 05:22 AM
rhargy's Avatar
rhargy is infamous around these parts
Depends on what you're doing with the car. I always thought the stock brakes were excellent for everday, aggressive street use, and even light track duty
If you're tracking the car, I like the Pagid Yellows up front and Black in the rear. I know a lot of guys like the Castrol fluid, but I've had really good luck with the ATE Super Blue for a lot lower cost. In my mind the real track upgrade for the 4 pots on the track is going to slotted rotors. Heat cycling kills the drilled rotors. Either Girodisc or Coleman.
Porsche brakes are very good stock. So if you're just using it on the street I would recommend saving the money and putting it towards something else.
Old May 3, 2011 | 06:03 AM
H8T WP's Avatar
well I do aggressive street driving and the occasional track day :P this was yesterday and today i need brakes lol
Old May 3, 2011 | 06:24 AM
JG GT500's Avatar
JG GT500 is infamous around these parts
Old May 3, 2011 | 06:36 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
pagid yellows front and back and some motul 600 and you have a great upgrade
Old May 3, 2011 | 06:48 AM
Tim941NYC's Avatar
Love that color! If you feel that the bite at first is to soft you can open up the hole that feeds the brake fluid to the front caliper.
Old May 3, 2011 | 07:03 AM
H8T WP's Avatar
Sweeet, i'm trying to find some of these in the UK to purchase online now but no luck yet :S do you know a part number or something?
as for opening the hole ill do that when i change em
Old May 3, 2011 | 07:09 AM
jpflip's Avatar
Tim ???? Can you clarified? In the caliper itself? Thanks.
Old May 3, 2011 | 07:21 AM
Blockhed's Avatar
Model: PAG-2474-RS29 Front
Model: PAG-2405-RS29 Rear
Old May 3, 2011 | 07:47 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I recently moved to this setup and noticed great improvement...
Front:
GT3 6 pot
997 350mm rotors
Pagid Yellow
Motul RBF660
Rear:
stock
Old May 3, 2011 | 08:23 AM
landjet's Avatar
Plus 1 for the GT3 6 piston calipers and 350mm rotors all around. I felt a definite improvement at the track. The front brake pad that goes with them is huge.
Old May 3, 2011 | 08:54 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Front:
GT3 6 pot
997 350mm rotors
Pagid Yellow
Motul RBF660
Rear:
stock
Did you go with drilled or slotted rotors? Since I switched to PFC 01's, great pads - bite hard, my stock drilled rotors have cracked quite a bit, I heard this would happen but wanted to try the pads before I changed to GT3 6 po/350mm. I will probably go with slotted rotors. I use Castrol SRF, I used the blue but brakes got mushy towards the end of the day at Homestead, since I switched no problems. These pads are great but generate a ton of heat.
Old May 3, 2011 | 09:36 AM
H8T WP's Avatar
im just looking for a quick solution then move on to bigger brakes in the future.
Will stock 997 (350mm) rotors work with the 4 pots?
Old May 3, 2011 | 10:18 AM
H8T WP's Avatar
How many litres of brake fluid do i need for a full flush ?
Old May 3, 2011 | 10:54 AM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Appr 2 - 2.5
Endless RF650 is one of the very best fluids around w highest boiling point and low compressibility = max feel.
Endless ME20 are some of the very best pads around for tracking. Just for street they usually make noise.
