Large Evap Leak Help Needed...
Old May 1, 2012 | 04:55 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I had that code as well. Replaced the gas cap and problem went away. Also my gas cap "looked" ok.
There cheap as well, I'd try that first.
Old May 1, 2012 | 08:00 PM
Tim941NYC's Avatar
there is a solenoid under the battery tray. But you really need to smoke it...
Old May 2, 2012 | 08:12 AM
sweeney186's Avatar
sweeney186 is infamous around these parts
Def. get a smoke test, will cut down most of the guessing game
Old May 2, 2012 | 01:29 PM
TimAZ's Avatar
TimAZ has a spectacular aura aboutTimAZ has a spectacular aura aboutTimAZ has a spectacular aura about
We are looking for the location on the car of the sensor pictured. This should be the fuel tank pressure sensor.
Tim
Old May 2, 2012 | 04:59 PM
Tim941NYC's Avatar
It is under the battery tray.
Old May 3, 2012 | 09:37 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Thanks Tim.
Now we have an idea how the system goes together we can do a leak test (once we figure out how to tie in; any suggestions for a couple of amateurs?).
If there really is a leak vs an intermittent component we'll be looking to pressure with helium and use a sniffer (we have these available to us). The DME manual is talking about using a hydrocarbon sniffer others talking about smoke testing. With a small leak we're thinking it will be tough to see smoke?
Old May 26, 2012 | 01:47 PM
TimAZ's Avatar
Update
Sad to say but the problem is still here.
I have replaced one solenoid valve on the engine that controls the vacuum to the charcoal canister and the two valves in the manifold in the right front fender. I bought a Dura metric and can see the tank pressure difference is a positive when it should be a negative. A friend has brought his car over and I have been to his place comparing values from his car to mine. I have vacuum at the charcoal canister and the canister flows air threw all three pipes but I have pressure in the tank. My canister is different from the drawings in pep. I have attached a picture. Any help here??? Please. J
Old May 27, 2012 | 01:24 PM
TimAZ's Avatar
Another Update
found the evap leek!!! It was the seal on the line conecting to the flapper (orange nipple)valve seen in a picture in this post on page one. It was luck that I found it. A friend was looking at the durametric while I was pulling on fittings and the tank pressure diff jumped.
Old Jun 7, 2012 | 08:59 PM
TimAZ's Avatar
As luck would have it...or NO luck would have it. This car seems to have found itself another evap leak before I could get everything to a ready state.The fitting that I fixed still looks good. Now the car has found something else to leak in the evap system. Is there any inde Porsche guys on here that really know these cars. I'm tired of replacing this and then that to see if it works...and so is my wallet.
Old Jun 9, 2012 | 05:24 PM
TimAZ's Avatar
Another update...this seems never ending. I was using the Durametric with the car running watching the tank vacuum. In the attached picture you will see a blue (check?) valve to the left of the shock. I was snapping my finger on it and it would vibrate or kind of a shuttering sound and I would see the car try to pull a vacuum. Then is would stop in a second or two. Is this a check valve and does that seem to be a failure mode?
Tim
Old Jul 14, 2012 | 11:25 PM
TimAZ's Avatar
Fixed
I went to the dealer and in a week they figured it out and fixed it. It was the housing of the flapper valve in the fill tube. It had a very small crack that was leaking just here and there. Thanks to everyone here for their help.
Tim
Old Jun 15, 2014 | 02:30 PM
Sam Lin's Avatar
Sam Lin is infamous around these partsSam Lin is infamous around these parts
Was the flapper valve part #12 in the first diagram?
Sam
Old Jun 17, 2014 | 06:27 PM
TimAZ's Avatar
Yes. It had a hair line crack that leaked here and there.
Old Aug 8, 2016 | 12:20 PM
IbanezGod's Avatar
IbanezGod is a splendid one to beholdIbanezGod is a splendid one to beholdIbanezGod is a splendid one to beholdIbanezGod is a splendid one to beholdIbanezGod is a splendid one to beholdIbanezGod is a splendid one to behold
anyone have a pointer on a 997 Turbo? I'm getting tired of this code and the new gas cap didn't help. Anything I can change or alter myself to see if the problem goes away?
carbonjim996TT
Sep 20, 2015 08:14 AM
BLKMGK
Sep 19, 2015 03:51 PM
MrMiggy
Sep 14, 2015 02:18 PM
rsdub
Sep 10, 2015 03:30 PM
sparks
Sep 8, 2015 03:03 PM
