The Mods which are a Waste of Money !
Old Aug 3, 2012 | 08:17 AM
  #31
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
Originally Posted by BlackHorseTurbo
I'm not offended. But if you have an opinion, please be prepared to back it up with facts. I'm defending this forum as you seem to have 6Speed confused with another forum. So, enlighten us on the Black Magic that there is "a lot" of around here. Those who spew BS don't last long here.
There is a huge thread of REAL WORLD DATA here (not a list of irrelevant dyno numbers): https://www.6speedonline.com/forums/...le-thread.html
Thank you for enlightening me.
Old Aug 3, 2012 | 08:39 AM
  #32
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
That's what I was trying to get to... everything works as one system. The OP cannot just say this and that are waste of money because one component may need to work with another component(s). I think we are on the same page.
Originally Posted by evil 996tt
Well, i think the OP has/had good intent but mods are subjective. Also, i think you can't look at each mod as an end all. They have to work together as a system. You can't expect to change one thing that supports "x" amount of something and have it work perfectly with the original system. Its like porting the heads and not using the right cams. Then again, i only joined a month ago so, what do i know..
Old Aug 3, 2012 | 08:51 AM
  #33
don johnson's Avatar
don johnson is infamous around these partsdon johnson is infamous around these parts
Originally Posted by f1crazydriver
I also have a UMW k16 tune.
I had a stock exhaust, UMW tune. I dragged raced a stock tune, FVD (Gen1, which is very small piping- search info on it. not the best for flow) exhaust car. 4th gear 60 mph to 140 mph.
Every time, only 2.5 car lengths pull . That is with my car with lighter in weight, LWFW.
After I got IC and exhaust. We have not raced since. My car dyno'd right on the numbers that a flashed/exhaust car should dyno at. With a bit more on the tq side.
Interesting.... The UMW tune raises boost from .9 to 1.1 which must equat to a substaintial increase in HP and Tq unless the computer is pulling back tons of timing.
That said, was the stock tuned w/exhaust car you raced an X50/S car? If so that would explain some as 60-140 an K24 car would have the edge.
Old Aug 3, 2012 | 08:59 AM
  #34
evil 996tt's Avatar
Yup, its all good. The only way i see this as being helpful is if we knew how the part worked or didn't work and other supporting mods and or goals. Not just, i had "xyz" part and its not worth it.
As i work on my build, i will try to dyno one part at a time. I will try to report real world data, according to my build. Not being a millionare, this will take some time but, i will report all..
Old Aug 3, 2012 | 09:31 AM
  #35
Dr_jitsu's Avatar
You joined a month ago. How can you make such a claim?
We have real world testing around here. If something doesn't work, you'll hear about it.
Let's hear your list of what works and doesn't work on your 996TT.
Or is your experience based solely on your Civic?
This. We need to introduce him to Ben (not Moores, Bad 107). Many of us have run the "tests," as to what works on these cars and the list has been very well established.
Back to the OP, these need to be removed from his list: 3" Y Pipe
Larger Intercoolers (unless you want to go 800 Bhp)
16K Billlet Turbos
Also, intake plenum produces benefits before 800 whp, not in hp, but in faster spool up and power down low.
Old Aug 3, 2012 | 09:44 AM
  #36
Dr_jitsu's Avatar
Don't be narrow minded. Just because i joined 1month ago doesn't mean i don't have experience.
You clearly missed the point. I'm not comparing two cars rather than the difference in how people share information about these cars. It seems this forum has a lot of " black magic" vrs real world data, thats all.
And i think the last time i checked, this was a free forum where you can discuss and share opinions, guess i was wrong. Sorry if i offended you
Todds point was that what works and what does not work has been thoroughly vetted. For example, there were pages dedicated to the larger plenum. Many pointed out that it did not increase power as claimed by the company selling that product. However what was eventually established was that it enabled high hp cars to make more power at a lower rpm (say 3800 instead of 4k) If you have been a member and regular reader you would know that fact.
Another example, we also had many many discussions over creating a fast car with a tiptronic. Craig (most of you will not know him) an early participant on this forum dumped tons of money into his tippy project with poor results. Todd also made the same attempt and finally (and wisely) decided to go w/ a 6 speed for a big power car. The same applies to IC's, new members come on and claim that the big ICs are a scam etc. when in fact they are a critical component of high hp set ups.
Nonetheless, we still have new people come onto the forum, reject our collective wisdom and insist they can do things that have been proven not to work well.
Old Aug 3, 2012 | 09:50 AM
  #37
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
Hold the conversation a minute....I have to go pop some more popcorn.
Actually, I really like this kind of exchange of ideas. It really helps us Porsche-shoppers in the decision process.
Old Aug 3, 2012 | 09:58 AM
  #38
evil 996tt's Avatar
Dr jitsu, thanks for taking the time to explain. While searching for all the results is a good thing to do, the OP just listed items and gave a, "yes/ no" rating. While i don't fully agree with the premise, it is somewhat helpful. My initial response was, great as it seems to ME that, there are a few items that get reviewed based on seat of the pants feelings.
If anyine thinks i am coming on here and saying that i know what works and doesn't work has misread my post. That being said, jumping on anyone case for not searching or knowing something is a bit rude and in a public forum, not very inviting. Seriously, i am here to talk about these wonderful cars and find out what people have done to their cars and more importantly, hear how people are enjoying them! I'm not here to be told my post count is to low and therefore can't post my opinion.
Old Aug 3, 2012 | 10:43 AM
  #39
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
I think a better way of posting this thread would have been more along the lines of "What mods give you the biggest bang for the buck?"
For example, the billet K16's are obviously an upgrade to regular K16's. But is it worth the money to buy the billets when you could put it towards another mod that may produce more gains?
Old Aug 3, 2012 | 11:10 AM
  #40
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
well I am very pleased there is so much active debate on this topic ! we all need to know what works together well and how or not at all
Old Aug 3, 2012 | 11:14 AM
  #41
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Originally Posted by machinegunt
What about welding the coolant pipes? Necessary mod for sure correct?
+1. Can't feel it, but not doing it can sure hurt later.
Old Aug 3, 2012 | 12:04 PM
  #42
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Exactly. The OP set this tread up on a more yes and no type basis. There are many variables with each mod mentioned. Some seem to be good for some and some seem to be good for others. It probably has to do with the combo each has put together more that each part "working" or not.
Funny "race gas" never made it to the worthwhile mod list....
Old Aug 3, 2012 | 12:31 PM
  #43
johnspeed's Avatar
Maybe the thread should read..Mods Waste Your Money......LOL
Old Aug 3, 2012 | 01:57 PM
  #44
JETmn's Avatar
JETmn is infamous around these partsJETmn is infamous around these parts
Honestly, coming from many different turbo car circles, i can't believe half the stuff sold that claims to make hp. There is vertually no testing done. Seems someone will post a dyno number and then stuff starts selling. Check out a DSM or Honda forum and everything has been tested and proved a million times.
I'm not calling anyone out, just making an observation. This should be a good thread. You should add "type/design" of exhaust too. I'm very convinced there is some snake oil there.
I know I am a noob to this forum also, but definitely not a noob to turbo AWD cars. I have been modding mine since '94. I have been lurking and reading here for several weeks. I also came from the DSM (eclipse)/EVO forums and they are drastically different. There is good information here and some members that have contributed a lot.
I think the above feeling comes from people spreading 2nd hand information. These cars are fairly expensive so you don't get the level of modification that you do on some of the other forums, so there is not as much data from the actual user being posted. Dyno sheets (besides from shops) also seem hard to come by. With the other forums I am on 50% of the people are running bigger turbo's, IC's, injectors, exhaust, fuel pumps, aftermarket ECU's, etc.
I am getting my 996tt in the late spring, so I am trying to figure out my upgrade path to get me where I will be happy with a reliable ~700awhp.
Old Aug 3, 2012 | 02:04 PM
  #45
I
Absolutely.... show me another gain that will outperform a turbo upgrade boost for boost.... ( tune required of course...)
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
