grumpling/grinding problem when I accelerate out of a turn. What could it be?
Old Aug 23, 2012 | 06:47 PM
plastex's Avatar
plastex is infamous around these parts
Ok, I have an 01' Tiptronic, and I noticed that when I accelerate out of a corner I was hearing a grumbling coming from under my seat area,(possibly a little bit forward of seat). I wanted to eliminate the wheel bearings, so I replaced them, and the problem is still there. I checked for play in the driveshafts, and the Cardan (sp?) shaft, and can't find any.
Any ideas?
Can I unhook the Cardan shaft, and see if the problem is still there? I've heard you cant run RWD on a tiptronic though.
Thanks,
Oscar
Akron, Oh.
Old Aug 27, 2012 | 10:21 AM
plastex's Avatar
anybody?
Old Aug 27, 2012 | 10:27 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I'd bet its your tranny mount. Those things are weak. And YES, you can run RWD in a tip. I did it for a couple years. I wound not do it again though.
Any ideas?
Thanks,
Oscar
Akron, Oh.
raineycd's Avatar
Just kick you old lady out next time you go driving! :-)
Maybe transmission mount?
Old Aug 27, 2012 | 10:28 AM
raineycd's Avatar
Dang Todd, beat me to the draw! lol
Old Aug 27, 2012 | 10:29 AM
ha
Originally Posted by raineycd
dang todd, beat me to the draw! Lol
Old Aug 27, 2012 | 11:06 AM
plastex's Avatar
when I was underneath I was able to pull on the Cardan shaft, and I got movement, but the movement was from the whole Differential,(awd) unit. I didn't see any play in the shaft. How can you tell if your tranny mount is bad?
Old Aug 27, 2012 | 11:14 AM
The center of the mount will look like this.
Old Aug 27, 2012 | 12:02 PM
plastex's Avatar
Can you see the damage when on the car?
Old Aug 27, 2012 | 02:05 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
It could be..................
There is a known problem with the 01 Tip have a look at this TSB.
However the easy and cheap cure is to use durametric, PST2 or PIWIS to reset the TCU adaptive values.
Basically, the car has bee driven for too long like a *****, reset the values and give it some **** now and again. Don't be afraid to show it who is the boss and really have a good hard drive. The TCU has adapted to being driven too slow in each tip gear. Believe it or not, its up to you but it really is true. On these Scottish roads its all too easy to drive the car like "Miss Daisy". So I have the same noise form time to time. Worse when under load at very slow speeds in 3rd. Normally going up a hill slowly and pulling away under mild load. It will also do it in 2nd and 4th.
Oh yes , one other thing, you can absolutely run a Tip without the front diff. just disconnect the shaft. In fact its the only way to roller test a 6tt whether tip or manual on a 2 roller system or for that matter IMO even on a 4 roller system .
Technical Information
911 Turbo (996)
5/02
3701
Binder
- 3, Transmission, Automatic
Tiptronic Transmission Noises
Vehicle Type:
Model Year:
Concern:
Information:
Work Procedure:
Parts Information:
Labor Operation:
Literature:
911 Turbo (9196)
As of '01 (1)
Tiptronic control unit adaption of the torque converer lockup.
Driving noises/jerking during acceleration.
Grinding/rattling noise when accelerating from a standstill or when driving at low speed in third gear
15
- 35 mph (30 - 50 km/h). Irregular /hard gear changes and jerking during acceleration also occur
occasionally.
The reason for this is the adaptation of the torque converter lockup clutch in the Tiptronic control unit.
If the vehicle is driven in a restrained manner or is frequently driven in stop-and-go traffic, the Tiptronic
control module adapts itself to unfavourable values that cause the aforementioned complaints.
This problem arises only if the car is driven in a comfortable/economical manner and not when it is
driven in a sporty manner.
Install a new Tliptronic control unit with modified software.
Introduction: 12th November 2002
99 53S 68 5844
USA
1. Install and code the new Tiptronic control unit, part number, 996.618.180.04, as described in the
911
Turbo {996) Technical Manual, Group 3, Chapter 373019.
2.
Carry out a test drive, making sure that all upshift and downshift points are reached. Do not switch
the engine off after the test drive, but instead let it idle for 10 minutes. The adaptation values will
be written into the transmission control unit only after this time has elapsed.
Part Number
996 618 180 04
Description
New Tiptronic Control Unit
Labor Operation
37 30 55 06
Time Units
130 TU
Description
Removing and installing control unit
Includes: Removing and installing rear side-panel lining
Programming the control unit
911
Turbo (996) Technical Manual, Group 3:
> Repairs: 37 30 19 - Removing and installing the Tiptronic control unit
Old Aug 27, 2012 | 02:46 PM
Good stuff Sunnyside lol
Old Aug 27, 2012 | 03:50 PM
Thanks matey
Old Aug 28, 2012 | 06:16 AM
plastex's Avatar
Ok, looks like the tranny mount is bad. I will get a new one on order. Any tips on installing it?
Old Aug 28, 2012 | 09:20 PM
jury_ca's Avatar
jury_ca is infamous around these parts
Does that grinding do any damage to anything? I replaced my tranny mount which fixed the issue, but always wondered what was grinding?
PV=nRT.
Sep 9, 2022 06:06 PM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
