Right wiper not working - Advice?
Old May 18, 2013 | 03:56 AM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
The passenger wiper doesn't move on my 996TT. It went from working fine, to working intermittently to not working at all.
Before I tear into it and see what I find, I thought there might be obvious advice.
I have no clue how it works, so any advice is welcome!
Old May 18, 2013 | 08:10 AM
Macster's Avatar
Without going outside to my car and exposing the wiper hardware there are two possible things (at least) to check.
The wiper arm is loose on the shaft and while the shaft rotates the wiper arm doesn't follow.
If the shaft doesn't turn and if the if the non functioning wiper shaft is driven by the other wiper via some connecting link the link has come loose or broken.
Old May 18, 2013 | 09:09 AM
jpflip's Avatar
Remove the battery cover. Remove the left cover over the clutch reservoir. Look at the condition of the linkages on the wiper motor. I suspect the linkage going to the right side being disconnected from the wiper motor. See picture....You can also start the wiper operation and look at the movement. Warning do not operate on dry windshield also be careful not to have the wiper away from windshield if you open the bonnet. The arms will contact and damaged the paint....
Name:	Capture d’écran 2013-05-18 à 11.06.23.jpg
Old May 18, 2013 | 09:15 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Most likely it is the bolt loose on the wiper.
Old May 18, 2013 | 10:54 AM
Steve B.'s Avatar
Steve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to behold
Remove it all together and plug the hole!
Old May 18, 2013 | 11:53 AM
jpflip's Avatar
Steve the OP mention the right wiper not the rear!!!!
Old May 18, 2013 | 01:49 PM
'02996ttx50's Avatar
LOL. was thinkin same
Old May 18, 2013 | 02:10 PM
Steve B.'s Avatar
Whoops! I was wondering why someone didn't beat me to it... makes sense now.
Old May 20, 2013 | 03:15 AM
metzos's Avatar
metzos is infamous around these parts
I would check the bolt first and then maybe the motor..?
Old May 20, 2013 | 06:47 PM
tscales's Avatar
Yeah, just a loose bolt.
Thanks all!
Tomp
May 5, 2016 08:04 PM
97GtsMonster
Nov 17, 2015 12:38 PM
su_maverick
Sep 15, 2015 02:57 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
