Boost issue... 0.5bar max sometimes, after warm it will boost to 1.1
Old May 29, 2013 | 03:14 PM
nimski62's Avatar
nimski62 is just really nicenimski62 is just really nicenimski62 is just really nicenimski62 is just really nicenimski62 is just really nice
I've been noticing that in the first 20 min of driving.. no matter how much I gun it, the boost drops off at a steady 0.5bar... and then in about 20 min of driving it becomes beast mode 1.1 bar EVERYTIME I floor it...
Giac tune.
Is there a reason for this? Any obvious things I should look at? No codes, no CEL.
Old May 29, 2013 | 03:56 PM
ttboost's Avatar
I think there is something in the tune that will not allow it to boost fully until warmed up?
Old May 29, 2013 | 06:05 PM
602996TT's Avatar
602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future
Check your MAF?
Old May 29, 2013 | 07:00 PM
MBH's Avatar
MBH
MBH has a spectacular aura aboutMBH has a spectacular aura about
I'm assuming that you're not going WOT before the fluids are up to temp. With that said, maybe some really weird kind of major boost leak that seals itself once the engine bay comes up to temp?
Old May 29, 2013 | 07:46 PM
wross996TT's Avatar
when was the last time you did TB cleaning? Changed plugs/coil packs? Checked WG's?
Old May 29, 2013 | 08:01 PM
nimski62's Avatar
Def not going WOT without atleast driving 10 miles.. I wasn't sure if there could be a boost leak that could seal itself after warm.. I will have to look into that.
Never replaced coils, plugs are on my DIY list very soon. Why would I need to replace coils if there were no CELs or misfires?
Would worn plugs cause boost issues?
Old May 29, 2013 | 08:03 PM
'02996ttx50's Avatar
sure. and/or misfires. coils same. tuned tt's are asking more of the components. they sometimes wear faster. esp plugs, i would think.
Old May 29, 2013 | 08:31 PM
unvmy996's Avatar
i doubt that any of the above anything to do with it , if it did then it would do it all the time not only when cold, Mike maybe on to something about the tune, i would contact them an check.
Old May 30, 2013 | 02:24 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
check the n75 valve with durametric at cold condition....klick klick klick noise if it works ...maybe it doesnt work when its cold (durametric under activations) easy to do and no cost for you
also you can check your dv`
Old May 30, 2013 | 12:21 PM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
I was having some inconsistent boost response similar to what you are describing. Occationally it wouldn't exceed .4-.5 bar, and then all of a sudden it would punch through to 1.5bar. I figured it was a sticky wastegate acutator. They are under the car, behind the tires and they unfortunately get a lot of grime on them. I got under my car (when cold) and moved the wastegates by hand. The driver side actuated smoothly, and the pass side had some more resistance and a little squeaky noise. I simply sprayed some WD-40 into the bushings and worked it in a bit by actuating the wastegate. Now I have a consistent .9-1bar of boost every time, it seems to have solved my problem.
So I'd say get under there and check your wg's, its easy enough.
YJosephTT
Mar 28, 2016 02:31 PM
Fadi
Oct 5, 2015 12:14 AM
Greehn
Sep 16, 2015 04:45 PM
johnny.dangerous
Sep 11, 2015 02:39 PM
rsdub
Sep 10, 2015 03:30 PM
