E85 / Proefi 996TT
Why would a nearly equally sized injector (just 150cc smaller) provide substantially better drive-ability? Are you saying the Bosch are just better units with a more controlled/refined spray pattern or is it high vs. low impedance difference?
its your car im not scared!
when i broke mine i learned the axle is considered a "mechanical fuse" allowing the axle to break instead of the mainshft in the trans.( the theory is better to break a 1000$ axle vs 6000$ TRANS REBUILD) of course randy's car is fully beefed up in the trans dept and can use the 1000 hp axles
Hmmmm you must be a "business consultant" or do you have a philosophy
degree?
very unusual spray pattern that doesn't lend itself to easy tuning.
The Bosch units are big but conventional and much easier to tune with.
In other words, it's def not the 150cc difference that makes the 2150's
difficult to work with. Maybe someone more knowledgable can chime in....
own!
Yep, keep your eye out for an axle for me. I really don't wanna pay 3k
for a new one if I can get away with it.
he brought it to my attention, I did a little research and there is a
definite consensus among the high end tuners that the 2150s are a
nightmare to tune.
Earlier in this thread someone made a comment to this effect. Errol is
tuning the ProEfi as if we were using the 2000's but it's giving everybody
fits.
i also dropped a line to my go to salvage guy to see what he has in stock. theres also a gmg 4 point bar for sale (700 plus shipping ) on the other forum
I have an axle if you need.
On the 2150s a lot is in the spacers not the injectors themselves. They are tricky when it comes to tuning, non linear.
Why does your power drop on the 800hp run ?
#TeamAIM
#TeamAIM
https://www.6speedonline.com/forums/...-axles-fs.html
until I get the big axle. My 2 step builds about 9 lbs of boost @3000 rpms
in 4th........not that big of a shock to the system. I'm gonna try revving it
up to 3500 and push the button. I got a 5.14 with making 9lbs of boost
going into the 60-130. If I can get another 150-200 rpms, I'll go into it
@ 10 or 11 lbs and it'll put me in the 4s!
I got a 5.18 with a 3-4 shift. All of this was in 70s and 80 degree weather.
If it was 50 ish, I'd already be in the 4s.
break this one in the mean time I;ll hit you up! Again, thank you
And yep, that what Errol was saying, it's the modification on the injectors.
I think the spacers effect the linear aspect down low especially. They do
an ok job past 2k but below 2k they're erratic.
Thanks Mark! I'm gonna try to find a decent deal on a 1000 hp job but if I
#TeamAIM
#TeamAIM
I've still got a lot of odds and ends to tie up on the car. I'm gonna do it over
the next 4 or 5 weeks and take a financial breather!
We probably have another 2 or 3 weeks of back and forth to iron out the
rough spots in the drivability. As for losing the power at the end of the 800
hp pull, we were just hitting a number and he worked on that setting several
hours afterwards.
It was literally a 100 degrees in that garage and he had 2 tiny fans on the
intercoolers and we were running e70 lol! I'll be hitting the local dyno when
we wrap the tuning up. I'm fairly confident it's a true 825 - 850 whp @ 28psi
It's been doing back to back 5.1s 60-130 in high 70 and 80 degree weather.
Yeah man 5.13 was my best at 775-800 power level.
4 second club is where u gotta be with your car
I don't like that dip , gotta keep looking at it and figure out whats up. Proefi logs everything so hopefully u can find the culprit. Might just be those turbos running out of steam on e70.
Speaking of .... Get some e80-85 in there
#TeamAIM
#TeamAIM
