Can I run M1 10/50!?
Old May 30, 2014 | 11:23 AM
'02996ttx50's Avatar
i've never even seen it. wanted a thicker summer weight and can't find any 5/50 locally. my tech has m1 10/50 and says it OK!? i'm a bit dubious.
any fast advice without ( an oil debate ) is appreciated! thanks
Old May 30, 2014 | 11:48 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Are you planning on road racing ? I would think the 10 weight a little rougher on cold startup
Old May 30, 2014 | 12:03 PM
i know. i've don't ever recall even seeing this before. ambient down here is never below 60 and up to 100+ daily soon enough so the 10 may be ok?. just wondering if its even "approved"!? i get screech at startup in 100 temps from "cold" since the 0-40 is like castor oil when hot!
Old May 30, 2014 | 01:00 PM
Tim941NYC's Avatar
I run 15w50. I do warm my junker up tho.
Old May 30, 2014 | 01:35 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
0-50 Mobil has a zinc ppm of 1850. So just run a 0 cold weight. I don't get why anyone runs 10-15 cold weight.
Old May 30, 2014 | 02:17 PM
had to make a snap decision. but instead found castrol synth 5/40 and 5/50 which i'll mix 50/50 lol. thanks guys.
i don't know where you guys find this 5/50 or even 15/50 M1 in stores. ll i ever see is 5/40 or 0/40 retail.
Old May 30, 2014 | 05:44 PM
Macster's Avatar
Additive package is very critical to a modern oil's ability to do its job. By mixing oils you have compromised the oil designer's additive package.
You have created a Frankenoil and no one can say how that will turn out.
As for 10w-50 no 10w-xx oil is on the approved list, so it is not ok to run it according to Porsche.
If you chose to stray off the reservation and run an non approved oil then you can pick the oil any old way you want. Makes no difference as you have disregarded the input from the only valid source.
I can find Mobil 1 5w-50 (not a typo for 15w-50!) at the Mobil oil distributor. The distributor sells the oil in minimum quantities of one case, 6 quarts to the case.
Since the distributor moved away from my area (near work) I stopped buying it from the distributor but I can now find it at least one auto parts store where I live. In fact, the SM at the dealer that services my car can get it for me at no added cost. The auto parts store will deliver it to the dealer with just a phone call.
Just had the Boxster's oil changed and had the tech use Mobil 1 5w-50.
Next time the Turbo's oil is due I'll have the dealer's service department source some 5w-50.
Old May 30, 2014 | 06:38 PM
the guys that tune/mess with my car and race them have been mixing 0/40 and 5/40 for years. if any harm has resulted? it would be news. but i change my oil often and these are similarly compounded synth oils. i really don't feel it's an experiment, as such. but thx for the headsup!
also.. i've read porsche's updated/ammended approved oil list. it's got bout 50 different oils and weights listed as ok. this has helped me move away from my formerly strict reliance upon M1.
ADD: yes macster, i neglected to point out to you by reply, that indeed, i am NOT going with the earlier available 10/50 M1 as it doesn't even SOUND right, given what little i know. i opted for castrol synth as stated upthread. it's ok on the "list".
Old May 30, 2014 | 07:04 PM
pwdrhound's Avatar
Any NAPA can get M1 5w50 for you. They don't have it on the shelf but can usually get it for you same day if you live in a large city. It's a great oil especially if tracking your car as it doesn't shear down as much and keeps your oil pressures up a little higher.
Old May 30, 2014 | 08:05 PM
thx. thats what i wanted initially, but didn't have time to special order or order online. 5/50 seems to be the consensus go to oil.
Old May 30, 2014 | 09:40 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Same here, but will switch to 5W50 next time. My Indy assured me it was fine, he uses it in other P cars etc...
Old May 31, 2014 | 06:36 AM
BretW's Avatar
BretW is infamous around these parts
I agree, check Napa. My local Napa stocks it. I run the Mobil 5-50 or turbo diesel 5-40.
Old May 31, 2014 | 05:28 PM
VGLNTE1's Avatar
If you watch ebay you can find deals too. I saved about 50$ on my oil just waiting for something to come across. Then I just stock up
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
BLKMGK
Sep 19, 2015 03:51 PM
Korntera
Sep 15, 2015 08:20 PM
captain Greg
Sep 6, 2015 04:14 AM
sleepy
Sep 4, 2015 11:59 AM
