Fuel Pump needs replacement - what direction?
Old Dec 6, 2014 | 04:48 PM
  #61
32krazy!'s Avatar
Originally Posted by SamboTT@ByDesign
Haha. Work in progress. Hopefully we will see some real parts in a few days
nice! gt2 parts and ceramic brakes. winning!
since its fuel related would a 2004 gt3 fuel tank work in the turbo? i can get a used unit for stupid cheap and like the thought of the extra fuel and no horseshoe in the tank.
Old Dec 6, 2014 | 05:32 PM
  #62
SamboTT@ByDesign's Avatar
It's a turbo with the body parts and stuff on it. But I promise I will not write GT2 on the deck lid! Yes that chassis is the same for GT3, turbo and C4 cars. If you have remove the front Drive stuff it should work. Exactly, and your gas gauge will not be useless below 3/8 of a tank!
Old Dec 6, 2014 | 06:47 PM
  #63
32krazy!'s Avatar
so i guess at 150$ i should get it then
Old Dec 6, 2014 | 06:50 PM
  #64
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
Yes get it!! The gt3/gt2 tank doesn't have the humps - not does it have the jet pump pickups. Note that the fuel pump basket is different - I care you don't have it.
Old Dec 6, 2014 | 07:12 PM
  #65
Craig made an awesome fuel system in his car but it's a little much for the average guy to put together.
Dude I want my car back! So much work to get this blue one even close!
Not to mention prodigy, Tim and so many others that did the research and development on their kits.
Old Dec 6, 2014 | 07:16 PM
  #66
32krazy!'s Avatar
well if my quick research is correct the boxster fuel tank is the same as the gt3 tank. they can hand for as little as 75$
vapor recovery system seems to an option as well even for the 200 and up cars. since mine is disconnected i would love to get rid of all of that and save a little weight
Old Dec 6, 2014 | 07:36 PM
  #67
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
A nice clean system for one 450 pump and stock lines for the guys who need that little bit more. (Many of us).
Great news Sam! Thanks for chiming in. This sounds like exactly what many of us are looking for! Any rough idea of a range the cost will come in at?
Old Dec 6, 2014 | 09:13 PM
  #68
LQQK's Avatar
You gave me a great starting point - and I've continued to add. Just finished carbon bumpers, and supports - took another 50lbs out.
Old Dec 7, 2014 | 10:57 AM
  #69
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Silly rabbit motorsports. They have done a lot in the Audi world. Spending time with engineering firms in the past I can understand and appreciate their efforts and techniques applied. They also have lots of experience with fuel consumption and the variables from pump fuel to race fuel to E85. After speaking with Sean it looks like there will be two options. A nice clean system for one 450 pump and stock lines for the guys who need that little bit more. (Many of us). Then a dual pump set up with upgraded lines and provisions all the way to the rails. Everything will be plug-and-play, mill spec and overbuilt. My favorite part is that it will be one of the cleanest best looking solutions. There have been some great fuel systems put together but they are just not a kit. And we all don't need 1200 hp lol.
I can see the point for 2 455 Walboros but you can fit a single in the stock system and the lines are adequate so dont see the point for a single pump upgrade, im going to try the JMS fired off my Syvecs S8 and 1100cc ASNU meth/eth injectors.
Old Dec 7, 2014 | 11:11 AM
  #70
There will be some pros and cons and it will be that expensive. I promise you will have info next week. You were in a position that you have syvex which is you so much flexibility. For others it would just plug right in and have mill spec fittings ready to go. Also no major modifications required. I guess it depends what you consider major or minor.
Old Dec 7, 2014 | 11:33 AM
  #71
Dont get me wrong this is great and I may end up buying a twin 455 set up instead of as the plan is now a magna and swirlpot if the pump booster does not work but the prices I hear quoted for a tune by some vendors makes the Syvecs a no brainer with the control it gives etc and its plug and play so can be removed and sold at any time, I went Syvecs for the ease of modding tunes with each modification and I have 8 maps available all pin locked at the press of a button.
Look forward to seeing the new basket when its done but 2 455's will need a -8 supply and -6 return to take full advantage of them.
BTW guys you dont need a Syvecs etc to run a pump booster it can be done by a boost reference and ups pump performance by up to 85%
Old Dec 7, 2014 | 12:12 PM
  #72
Another little FYI. The two small black rubber hoses on the fuel pump assembly need to be replaced or reinforced if you are upgrading fuel pressure. Those are the ones that always split with higher pressure.
Old Dec 7, 2014 | 02:15 PM
  #73
pwdrhound's Avatar
That's a good deal. You will also need the tank gauge, fuel pump basket, venturi tube, retaining straps, and a couple of other odds and pieces. It's about $1200 worth of stuff. Install is a bit involved as the power steering rack will need to come out along with some suspension pieces.
The GT2 tank uses on jet pump as opposed to two on the TT. You have to get the fuel into the basket somehow. In case you decide to pass on the tank, let me know as I might be interested.
Old Dec 7, 2014 | 03:00 PM
  #74
ASLAN's Avatar
Good point Sam. Is there a U-shaped hose replacement available? Based on what I have read, when guys blow this hose, the whole pump assembly has to be replaced. Am I understanding that right?
Old Dec 7, 2014 | 03:09 PM
  #75
32krazy!'s Avatar
its local to me i have to see what all is included with the tank. could be everything maybe nothing. fwiw it seems the boxster tank is the same and theres about 20 around the country from 75$ to 300$ were are you located i may see one close to you at the same price.
i did find out it seems the 2004 gt3 tanks are 67 litre tanks while the older pre 2003 can be had with 90 litre capacity. thats the one i would like to find
