ABS PCM Problem
ABS PCM Problem
Hey Guys, I know there has been many posts about this but after reading a bunch of them it seems that most are related to a wide variety of problems. This what happened for me.
First of all let me start by explaining what happened seconds before the "failure" messages came up. I was putting the car through some WOT(testing Intercoolers) on a very twisty and hilly road and it was only 40deg out(bad combo). At one point, at the crest of a small hill followed be a left turn(very close to airborne), the ABS & PSM kicked in significantly. I'm not sure if it was necessary or if the system saved me from a bad crash down into a cranberry bog. After the Failure message and the ABS PSM lights were on, the front left wheel seem to not have ABS. I am guessing the ABS sensor crapped out? Also of note is that my scanner says they are no codes to report even though both ABS and PSM lights are on. Will the lights and Failure message clear out in time? Thoughts?
probably boost leak... something popped off
2001 996TT 3.6L and stock ECU
Thanks...I thought that as well...did a boost leak test everything was fine. This happened right after the car was sideways, I wasn't even on the gas at the time but was going way to fast up a hill with a left and turn at the crest of the hill.
Lights are permanently on, no codes on the scanner, power is normal, front left wheel locks up under hard braking(no ABS on that wheel)
what scanner? you need a durametric cable
