Anyone pick up the Cobb Accessport for their 996TT?
Old Mar 10, 2016 | 12:16 PM
  #91
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
Cool
Not sure on the boost level for the 91 map but you should definitely do a leak lest as soon as you can.
Originally Posted by evilruss
Recently purchased an Accessport for my 2001 996 and installed the stage 1 91 octane OTS map and immediately had some stumbling or stuttering under any heavy throttle. Swapped in some fresh spark plugs which I think were still the originals and that seems to have cleared up the problem. I did find when I had things apart for the plug change the driver side inlet hose wasn't completely locked into the retaining clip and based the greasy buildup at that connection it had been that way since prior to me buying the car.
Prior to the reflash I was typically seeing .6 bar in the dash with occasionally hitting .7 bar. Now I typically see .7 bar with occasionally hitting .8 bar. I'm assuming both the stage1 91 octane and 93 octane maps are 1.0 bar and the 91 is just a safer tune.
Can anyone confirm this is the case and not that the 91 octane is lower boost?
So if the map is indeed 1.0 bar, I'm wondering if maybe either the display in the dash might be inaccurate and I need to actually log with the Accessport to see the accurate boost numbers, or I have a boost leak, or if by chance there might be an issue with one of the turbo's or wastegates. The intercooler hose that was loose on the drivers did seem a bit oily inside.
I believe the diverter valves were replaced with the uprated version of the stock valves a couple years back. My plan was to do some logging next to see if that reads different from what I'm seeing displayed on the dash reading. If that wasn't different find some 93 octane and try the stage1 93 octane map. I also haven't done any sort of boost leak test yet so that's also on the list.
Old Mar 10, 2016 | 12:40 PM
  #92
evilruss's Avatar
evilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud of
Alright, boost test asap it is!
Is this a suggested method? I saw mention of pulling the airfilter housing and maf, but this looks simpler to pull the inlet hose at the turbo compressor. Seems the most logical as the boost starts on the other side.
https://www.6speedonline.com/forums/...ig-w-pics.html
Old Mar 10, 2016 | 01:31 PM
  #93
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
Remove the compressor outlet hose and plug that rather than filling compressed air to the inlet of the turbo.
Old Mar 10, 2016 | 01:53 PM
  #94
evilruss's Avatar
Ok, I'll look at testing using the outlet hose then. Is the idea being to avoid potentially pressurizing the oiling system?
Old Mar 10, 2016 | 02:46 PM
  #95
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
I'll wait for markski to jump in here, but boost leak test is huge on these cars. There's a ton of lines that can rip or come off (especially by the plenum behind the throttle body) which can throw off a lot of things.
I also wouldn't trust the gauge in the dash, what is the accessport saying it's hitting as far as manifold pressure?
In terms of stuttering, coils and plugs should really be the first mod for these cars, mine failed almost immediately once I started modding.
Mitch can probably tell you what the OTS tunes are supposed to hit but I bet they are over 1 bar and you have a boost leak somewhere. Make or buy a kit and test first before moving to the next step.
Old Mar 10, 2016 | 04:49 PM
  #96
sinKing's Avatar
Yep.
Logging is very easy then you will know exactly what the tune is targeting.
Old Mar 11, 2016 | 07:40 AM
  #97
evilruss's Avatar
With the immediate stuttering I stopped getting on the throttle right away and didn't get it logged. Fresh plugs did indeed fix the stutter but was a short drive and didn't have the accessport hooked up to log. I'll start with the boost test and if I don't find anything then next step will be to get a couple logs with the manifold pressure and see if that is actually showing different then the dash.
I'll report back on the boost test results. Thanks for all the responses!
Old Mar 11, 2016 | 03:53 PM
  #98
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
My money is on a leak somewhere!
Old Mar 11, 2016 | 04:39 PM
  #99
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
Get the windshield mount for the AP. It makes logging and looking at the real time values so much easier. Also, the fact thats only around $15 on amazon makes it a no brainer.
Old Mar 11, 2016 | 04:45 PM
  #100
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Has anyone picked up the Access Tuner Race for the COBB in order to DIY tune? It says in their site, that it's the same software that Pro users use, except for no locking of maps and can be shared.
Old Mar 14, 2016 | 08:37 AM
  #101
evilruss's Avatar
I hooked the accessport back up and did two logs in 2nd gear which confirm the manifold pressure is showing lower than the dash at around 5-6psi max vs .7-.8bar.
The same logs are also showing lean afr's and knocksums during boost, so the car isn't coming back off the lift until I find something. I'm hoping the afr's are related to check valves and the fpr. I've pulled one of the turbo to IC hose's off the car to make it easier to put together a boost leak tester, and currently looking at MARKSKI's thread on "Boost Leaks- how to find them...."
Old Mar 14, 2016 | 10:41 AM
  #102
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Just got my car back up in running after a major engine out for preventive maintenance and upgrades.
1000cc Cobb injectors, to go with my A28 turbos. 5 minute flash with new MAFless tune.
Effortless startup and running!
Just shaking her down today, but drive-ability is spot on. Haven't given her to boot yet, but part throttle drive ability is where the magic is, and she feels stock.
Can't give enough kudo's to Sam from ByDesign for his guidance and tuning.
Old Mar 14, 2016 | 11:12 AM
  #103
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
It is the same software just can only be used with that accessport unlike pro tuner which can be used on any accessport.
Old Mar 18, 2016 | 03:02 AM
  #104
heavychevy's Avatar
I just got a Mafless Cobb Tune from the guys themselves. Motor has never been this strong before. Accessport has changed the game for sure. Made 596 wheel torque and so had to dial it back a bit.
Old Mar 18, 2016 | 01:18 PM
  #105
SamboTT@ByDesign's Avatar
Awesome Heavy! Thanks for the kind words and run. Paul and ready for you!
