Tial alpha 2871 compressor failure (pics)
Old Jul 9, 2015 | 05:22 PM
sshrum's Avatar
sshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant future
3 month old turbos (less than 700 miles on them); was doing about 50 mph around 4-5k rpm (boosting). Heard a pop and thought I popped a hose off. Limped home and all the hoses are solid. Pulled driver side intake first and found fan blade pieces. Driver side compressor wheel intack but chewed up. Took passenger side intake off and found massive failure. We think that once the passenger side fan blew up, the driver side intake sucked the pieces up over the Y pipe.
ID:	423601   Click image for larger version
ID:	423602   Click image for larger version
Old Jul 9, 2015 | 05:33 PM
32krazy!'s Avatar
wow that is a massive failure. I'm sure your aware this has likely reached the i/c and possibly the engine. need to drop the oil and cut the filter apart and search for internal damage as well
Old Jul 9, 2015 | 05:34 PM
sshrum's Avatar
Towing to a shop next week for compleye system check.
Old Jul 9, 2015 | 05:35 PM
BLKMGK's Avatar
That would be pretty impressive if it could spit pieces all the way up and around through the convoluted intake piping! Fingers crossed that the intercoolers caught all of the trash and kept it out of the motor :-( I'd be changing the oil ASAP! Did it lose the nut on the compressor maybe?
Old Jul 9, 2015 | 05:46 PM
'02996ttx50's Avatar
sorry to hear. never seen this. yikes.
Old Jul 9, 2015 | 05:49 PM
sshrum's Avatar
Yeah...the nut sheared off.
Old Jul 9, 2015 | 05:51 PM
i'd be in effin tears. you're holding up well. especially sucks given how much you've recently put into the car time/effort etc.
hang in there.
Old Jul 9, 2015 | 06:25 PM
sshrum's Avatar
Not finding very many metal fragments in the hoses which is concerning. I should be finding a crapload...wondering how much made its way past the ics. The whole intake system is gunna need a shakeout. Won't really know until I have the shop look at it. Was gunna do it myself but I don't have a lift tall enough to make everything easy plus if the engine needs a drop, it's beyond my comfort level.
Old Jul 9, 2015 | 06:38 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
That sucks man! So curious if the shaft separated/broke which caused the failure? Who knows right now. Had that happen to me once on my single turbo supra. Not fun. Good luck!
Hopefully the shop can get a to root cause - lubrication, balancing, pure luck(bad kind), etc. Let us know!
Wait where's that nut on the front side of the inducer? Did you find that too?
Old Jul 10, 2015 | 12:46 PM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
Pull the oil filter..........you will know right away.......
Old Jul 10, 2015 | 01:25 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
Not sure if you posted before but curious as to what is your setup.
Old Jul 10, 2015 | 01:27 PM
^ i think its his sig line? i recall he just completed a bunch of work on it?? thats what makes this that much more depressing to read of ugh.
from all appearances, those are well thought out and compatible mods. this shouldn't have happened!?!
Old Jul 10, 2015 | 01:29 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Damn thats bad luck dude, hope the motor is OK, I lost a A28 after like 20 miles but that was exhaust wheel.
Old Jul 10, 2015 | 01:31 PM
YJosephTT's Avatar
Doh... It wasn't on all his posts, LOL RIF! (remember that)
Old Jul 10, 2015 | 01:33 PM
!!? is this some kind of a "known" issue and is it also possible with the 30 series? rebuilt.. or .."new"? wtf.
