2 electrical problems
Old Sep 8, 2015 | 12:55 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Ok so on the turbo I bought I have 2 electrical problems and I'm sure they are both easy to solve.
1: the intermediate wipe switch or function doesn't work. You can turn the **** and it will wipe one time then stop and not come back on again. **** need to be replaced?
2: I hva e a gt2 wing and trunk on the rear but the failure light forthe turbo wing still comes on. Fuse, unplug a sensor?
Freddy
Old Sep 8, 2015 | 02:27 PM
rmc1148's Avatar
Probably a bad wiper switch. The spoiler light can be jumped and shut off I believe blkmgk put it in a post, also have seen harness adapter sold by deck manufacturers but not sure if available separately?
Old Sep 8, 2015 | 09:36 PM
BLKMGK's Avatar
Rear wing originally had two limit switches, one for up and one for down. Locate these and close ONE of them - I cannot recall which one so trial and error is in order. Do not close both, you'll get a light - guess how I know .
Old Sep 9, 2015 | 12:36 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
1. replace the ****
2. when the rear spoiler ltg comes up? at speeds or it stays all the time?
Old Sep 9, 2015 | 12:56 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
I don't think i have ever used my wipers ;-)
Old Sep 9, 2015 | 02:51 PM
flewis763's Avatar
Originally Posted by MadWhip
1. replace the ****
OK I'll get a **** for that. As for the spoiler light it come on at speed. Actually usually when decelling from higher speeds
Old Sep 9, 2015 | 02:52 PM
flewis763's Avatar
Ya it rains here lol
Old Sep 10, 2015 | 01:08 PM
MadWhip's Avatar
for stock oem spoiler/motor you should have harness. engine compartment/right hand side coming out of the wall. for stock wing it goes to right ram, I disconnected the switch from the ram and taped it together so it wont trigger. no more red light, since i removed entire motor assembly.
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
Lucid Moment
Sep 12, 2015 01:12 PM
nal991
Sep 11, 2015 09:05 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
