Blown motor pics.
i looked at a few cranks online and they were junk. i know a guy who buys wrecked turbos and parts them down to the core he may have ine if you do need a crank. let me know
I'm wondering when do you guys floor your car what rpm? Everyone ask me that when I had 16g billets I said most of the time I'm about 4K rpm. Others at the car show told me they like to floor it around 3K rpm in 3rd gear or lower in 4th gear eeeekkk.
I think there is an issue with flooring it to low in rpm. This guy blew his up in 5th or 6th gear at 170mph. Most people I see on here blow there motor in 4th or 5th gear at low rpm. Just weird.
I got rid of my 16g billets because they hit to hard down low. Lucky I would floor it around 4K rpm.
Some of you may remember me, I blew up about 2 years ago running 18g billets, 60lb injectors, and protomotive tune. Car ran great but when I went hard to 170 it seized. Now taking her apart to rebuild. I will post ongoing pics of the damage. Looks like it ran lean and seized the cyl farthest down the fuel injector supply system.
The crank may be good, but to break a rod I would suspect it would be out of specs, from the force of doing so. With the expense of the parts and labor to assemble this engine, not replacing damaged parts will be expensive. Rebuilding these engines is all or nothing IMO simply because of the cost involved and risk for failure of compromised parts.
Do you know for sure if it was low end torque or lean mix that caused this?
What are tuners doing to prevent to much low end torque when using modern turbos?
Is it as simple as limiting boost pressure below 4-5000rpm?
Tough to say from the pics if it went lean or not - would need the logs to see. And if it did it could be a combination of a number things.
It's too bad. But I'm sure you can build it back better.
Anyone watch "roadkill" the hotrod mag youtube show?
They made a good point in that the best way to test a tune on a car (you're going to buy) is to put in in 4th at low rpm and floor it. If you don't hear any knock and don't have to pick up bottom end parts the tune was probably solid.
