Blown motor pics.
Old Mar 22, 2016 | 09:20 AM
  #61
32krazy!'s Avatar
I have a set of used fvd 3.8 pistons and liners. Fvd has replacement rings for 500$ if flewis doesnt want them ill let them go cheap
Old Mar 22, 2016 | 09:44 AM
  #62
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Originally Posted by 996tt550hp
Yeah looking at the damage i think 8 to 10k is way to low. Just a crank your looking at 5k alone. You need a bottom end and tons of parts. Rods are going to cost 2k. Im sure the bottom end will be in the low teens.
Not so, very reputable 6 speed members have offered me good low mileage parts at good prices. A good used crank is $1000. Nothing wrong with a crank with less than 40k on it. Once I get my situation figured out I will make some calls and start collecting parts.
Old Mar 22, 2016 | 09:50 AM
  #63
brnrdtns's Avatar
Originally Posted by Npherin
Was your engine light on before hand? Did the light come on during the pass up until it seized? What code?
My theory is that I ran lean in the cylinder the farthest down the injector row. I think this caused some pre ignition and destroyed my rod. You can see that the carbon build up on the blown cyl is washed clean from the heat. I advise upgrading your fuel pump if you do turbos.
Old Mar 22, 2016 | 10:10 AM
  #64
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
How much boost pressure were you running?
Old Mar 22, 2016 | 10:57 AM
  #65
brnrdtns's Avatar
My tune is for 1.2 bar but I was in cold weather with around 94 octane gas and it was sitting at 1.3 during the run, which was probably part of my problem.
Old Mar 22, 2016 | 11:02 AM
  #66
brnrdtns's Avatar
Ok, I will consider my top end options once my bottom end is complete. I will keep this in mind. Thanks for the offer.
Old Mar 22, 2016 | 12:36 PM
  #67
Oh man, hearing that scares the crap out of me.
Old Mar 22, 2016 | 06:44 PM
  #68
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Wow scary! I have my Sam K16 billets on my workbench table ready to get started. I have delayed because I'm spooked on removal of the turbo oil lines as I tried last year and the line didn't budge without spinning as a whole.
I was going to heat them with a torch and attempt again soon but seeing this scares me!!
Old Mar 22, 2016 | 08:31 PM
  #69
cdk4219's Avatar
cdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to all
Got it apart. Crank journal looks to have taken a beating smacking against the broken rod pieces. Not sure if I should repair or replace. The oil pump is not cracked. The connecting shaft between the IMS and the pump took a beating. The oil pump might have sucked up some aluminum shavings and it feels lumpy when I spin it, not smooth and free spinning. Not sure if this is normal. I wonder if it can be rebuilt.
I am having a difficult time with your questioning the condition of the oil pump and whether it should be reused. If I were just re-ringing and re bearing a ford 302, the oil pump would the first thing in the garbage receptacle, especially if it has seen this failure.
Old Mar 22, 2016 | 08:39 PM
  #70
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Looking at that cylinder you have had an issue for awhile.
18g turbos hit hard down low with torque.
60pound injectors on 18gs probably had a high duty cycle.
A fuel pump would not just lean out one cylinder out of 6. This is the reason i say to people and others have told me dont go above 80% duty cycle. Once a fuel pump goes it goes even im still on a stock fuel pump but with 80pound injectors.
I would not rebuild this engine yourself alot could go wrong as another forum member tried this and blew it up twice here in atlanta. I would get SRM to get your motor done. Just an idea for ya.
Old Mar 22, 2016 | 09:33 PM
  #71
brnrdtns's Avatar
Any ideas about the problem? I thought the head gasket looked good.
Old Mar 22, 2016 | 09:36 PM
  #72
brnrdtns's Avatar
It costs $1500 new and is a reliable design.
  #73
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
I still vote for a more thorough look at the HG/head/studs...that cylinder looks just like a coolant drinker...and based on the severity of damage I further think hydro lock...
Originally Posted by 993GT
yikes!
kind of looks like a failed HG/hydro-lock scenario...water does an amazing job cleaning the combustion chamber...
Old Mar 22, 2016 | 09:42 PM
  #74
996tt550hp's Avatar
You know that could be an idea as mentioned above. Im wondering if you had the head lift from to much boost or pressure? It does look like it was washed down its shinny clean. Have you ever ran higher then 1.3bar?
Does anyone else think he lifted the head and coolant locked the motor?
Old Mar 22, 2016 | 09:46 PM
  #75
brnrdtns's Avatar
It did spike to 1.4 for a second. Lifted head?
