Vanity mirror cover . . .
Old May 28, 2016 | 01:09 PM
OhioC5's Avatar
OhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to behold
. . . Fell off when I opened it. I understand this is a common problem. Swapped it out today with a new one. Overall it wasn't too bad. The hardest part for me was soldering the wires with the mirror hanging there. I bet if I would have looked first it would have been easier to take the whole visor off and do it on the bench.
Pics, because I like pics.
I have this roll of 3M vinyl wrap and have not had anything I wanted to wrap yet. Never tried to cover anything with wrap before. I took the old broken vanity mirror cover for practice. This was for practice as I just wanted to see how hard it is to use. It doesn't look too bad, maybe I'll screw it to my work bench.
Next project will be the turn signal stalk switch. My signals don't cancel after turning. Research tells me it's most likely the entire assembly needs replaced. I watched a video on youtube, hoping it isn't too bad. I just bought the car and these are the only two things that need addressed.
Any pointers on the swap?
Old May 28, 2016 | 01:41 PM
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
Had to replace my vanity mirror cover as well. FYI you can use rubbing alcohol to remove the warning message and you will end up with an all black cover.
Old May 28, 2016 | 01:52 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
I had the same issue on the turn signal when I accidentally "held" the stalk while turning. Snapped something inside. The swap was pretty easy if I recall.
OhioC5's Avatar
Ok, thank you. After looking at the new one I noticed my passenger mirror cover looks kind of old. I may just replace it so they look the same. Did you solder the wires with the sun visor in the car or did you pull it off?
Old May 28, 2016 | 01:53 PM
BLKMGK's Avatar
I have an airbag sticker that looks OEM that instructs female passengers to remove tight fitting things like bras I'm going to replace my warning with. It's a close enough to OEM look that it ought to get some double takes
Old May 28, 2016 | 01:57 PM
OhioC5's Avatar
That's awesome, I'd like to see it.
Old May 28, 2016 | 02:14 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
haha, saw that on eBay.
djcooper@rennkit.com
Old May 28, 2016 | 03:13 PM
BLKMGK's Avatar
I'll try to snap a pic tonight, it's on my fridge waiting for my car to return lol.
Old May 28, 2016 | 04:41 PM
Benzoboi's Avatar
Benzoboi is infamous around these partsBenzoboi is infamous around these parts
Old May 28, 2016 | 07:17 PM
OhioC5's Avatar
Thank you, that will definitely help.
REDNOSEGT
Bentley
25
Feb 12, 2024 06:39 AM
TCZ
May 29, 2016 08:32 PM
flewis763
Apr 1, 2016 08:06 PM
Tinn1
Mar 31, 2016 05:08 PM
dhope618
Mar 26, 2016 06:59 AM
