need some advice for a problem with the gt2.
Old Jan 9, 2006 | 03:37 AM
M3j0n's Avatar
M3j0n is infamous around these parts
OK, I've always thought i had a problem with something on our car. Today confirmed it.
There is a digital boost guage on the cluster, which you all know. Mine was always at 0.0 since we got the car. It has never changed. I drive with that setting on the cluster 90% of the time. I figured that it must be reset and not be an actual time boost meter. Today the car read 0.2 and 0.1 boost (i guess due to the weather). The temp is about 50 when this happened, which is the coldest temp i have run the car at.
I did take it to champion once before, but they said everything was working properly when it was reading at 0.0.
anyone know what the heck is going on? The car pulls like an animal and you can hear the turbos, so its making more than 0.0- 0.2 lbs of boost.
thanks.
-jon
Old Jan 9, 2006 | 04:18 AM
never seen it b4
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 9, 2006 | 09:41 AM
Ruiner's Avatar
I think that you need to take it back to Champion and tell them to fix your gauge cluster. I have never seen this issue before, but I would imagine that the gauge is not communicating properly with whatever method that it uses to check boost pressure (whether it be directly from the ECU or from a vacuum hose).
Old Jan 9, 2006 | 10:16 AM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Sounds like the gauge hasnt worked properly.
Old Jan 9, 2006 | 10:17 AM
iLLM3's Avatar
Are you sure its pulling like an animal or sounding like one? Is the turbo spool up extremely loud and then when you let off it sounds like an aftermarket blow off valve? When doing my spark plugs, my shop didnt tighten or lockdown the clip for the hose connecting to the intercooler, he literally just pressed on it when i got tot he shop and no problems. It was reading .1 bar and not really moving anywhere LOL, sounded so sick though
Old Jan 9, 2006 | 02:29 PM
M3j0n's Avatar
nope, it doesnt sound like a blow-off valve. I have an oil service coming up, so i guess ill have them check it out again....
Old Jan 15, 2006 | 01:49 AM
M3j0n's Avatar
wow, champion said it was normal! i guess when i have my stuff installed at orbit racing, ill have them check it out for me. Danny at Champion said "0.2 is normal for the GT2." WTF?
Old Jan 15, 2006 | 01:57 AM
renntech36's Avatar
renntech36 is infamous around these partsrenntech36 is infamous around these parts
.2 is normal. wow I always thought Champion were idiots, but I guess that proves it.
Old Jan 15, 2006 | 01:59 AM
iLLM3's Avatar
Yea seriously, they have no clue what they are talking about.. I would definitely get it really checked out, sounds like the prob i had but who knows
The Bogg
May 22, 2018 08:19 PM
XCUDB
Apr 13, 2017 05:09 AM
adnanm3
Oct 25, 2016 08:38 AM
nal991
Sep 11, 2015 09:05 AM
HIX
Sep 9, 2015 04:45 PM
