A running pictorial of my monster Protomotive build
Originally Posted by topgun
Craig, for what I hear the water cooled engines don't really benefit from this mod. If the heads were to lift off slightly your toast anyway! As far as the air cooled brothers if the head lift off no big deal, they come back down no issues! (head gasket, coolant) On my 930 (3.6) I had this mod, on that engine worth every penny. IMHO. Maybe one of the tuners could shed some light.
Good luck with the build . . . you will surely have a beast.
Craig
2001 996TT 3.6L and stock ECU
Originally Posted by MARKSKI
My evo8 has the O ring grooves as well... it's a must.
I believe I remember pics showing that you o-ringed your liners. Did you o-ring your heads? I believe the cost of doing both is about 2k. The only person I know that o-ringed the heads/liners was VRAlexander. I know he ran 1.7 bar, maybe more and he didn't have any head failures that I know of. Then again we haven't talked since he left.
Originally Posted by DMK
he had no head problems period.
Protomotive through VRAlexander's car was one of a couple that truely pushed the envelope and raised the bar. We were so impressed with the work that we stopped our motor assembly to have Todd @ Protomotive machine our heads and liners for the o-rings.
Originally Posted by cjv
markski,
Originally Posted by Divexxtreme
Both Mark and I have had our heads and liners o-ringed.
The next question ......... from what material is your rings made ? There are a few materials that will hold the pressure. Certain ones will transfer heat while others will help disipate heat. This can have an effect on how far your push the timing. Same hold true on liner material.
Originally Posted by turbodickie
Scott: Is it ready yet?
