A running pictorial of my monster Protomotive build
Old Mar 25, 2008 | 04:13 PM
  #406
WOODTSTER's Avatar
Very true^^^^^^^^^^
Old Apr 1, 2008 | 10:51 PM
  #407
Turbo Fanatic's Avatar
Totally cool stuff. Congrats man!
Didn't read all pages so forgive if it's a repeated question. Any idea why the TT springs are stiffer? I would think that the GT3 springs would have to be stiffer to avoid valve float at the extended RPM. If the TT has has higher lift, that might explain it since the springs would have to work hard over a longer range?
Old Apr 2, 2008 | 05:44 AM
  #408
Divexxtreme's Avatar
Good question, Ari. Unfortunately I don't know the answer. My springs are custom so it makes sense that they're stiffer...but I'm not sure about the stock springs.
I'll point Todd to this question.
Old Apr 2, 2008 | 06:47 AM
  #409
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
I'll take a stab at this, I can't speak for a tt motor, but i've built a few..lol.. blown alcohol motors. You must always figure in boost pressure as well as rpm, ie, if you are running 55 psi boost it is trying to push the valve open, as well as your rpm. We figured the force aganist the valve due to boost pressure and added this # to the spring pressure. In my alcohol motors this was 425-450 at the seat and about 1200lbs open. Thus the need for 9/16 inch taperwall pushrods and 1" double roller lifters....
Old Apr 2, 2008 | 07:38 AM
  #410
TRK's Avatar
TRK
TRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to behold
Valve springs
Derboost is right on with the boost thing. Figure, if you have a 2" inlet valve, the surface area is pi r ^2, or 3.14159in^2, and at 1.5 bar of boost, you'll have 68lbs of pressure trying to force the valve open... Well, if you only have 80lbs or so of seat pressure, the valve is just barely sealed, where on a gt3, you'd have the full force of the spring applying to seating the valve.
However, the gt3's also have another advantage that allows for lighter springs. The lifters are maybe 1/4 of the weight of the 996tt's as they not only don't have the variable lift stuff going on, but also are smaller in diameter. The rsr's go even further and remove the hydraulics and have a mere shell as the lifter, so with the same spring, they have proportionately higher rpm capability just due to the lower mass of the system involved.
Old Apr 2, 2008 | 08:24 AM
  #411
WOODTSTER's Avatar
Nice ^^^^^^. The Professor has spoken...listen up!
MK
Old Apr 2, 2008 | 12:10 PM
  #412
GT RUS's Avatar
GT RUS is just really niceGT RUS is just really niceGT RUS is just really niceGT RUS is just really niceGT RUS is just really nice
Originally Posted by MARKSKI
k24/18gs are good for 600 to the wheels but the car is more responsive then a gt30r turbo car. GT30.s require water cooling and extra fab work to fit them so the cost to benefit ratio should be considered as well. the 044 mm tial WGs are not cheap either. Looks liek the gt3076 is a good turbo.... no issues there...
Bobby has K24/20s in his white 996tt and hes produced 720 rwhp as well.
markski
Mark...I am confused how much power did Bobbys car made at the end ???
Old Apr 2, 2008 | 12:17 PM
  #413
GT RUS's Avatar
I answered his many questions on other threads he started...
his questions are so loaded that I can spend a month answering... and I don't have time.
He want's the best of both worlds.. a reliable car in Russia without any mechanical local support putting down 800rwhp or more that will not break down and launch liek a bandit while not braking axles or tranny and beat some of the most powerful P cars in the world... ( 9ff, ruf, enzo, ect).
good luck..
markski
Thanks...you forgot to mention that it need to run on a pump GAS...
So there is no such P-car made yet for my needs...
What set up does the 996TT need to have car has to beat Ford GT TT ???
Old Apr 2, 2008 | 12:26 PM
  #414
WOODTSTER's Avatar
A ford GT TT engine in a Porsche
Are you nuts GT RUS?
Get a Viper GTS coupe, throw a couple of 74's on it and call it a day.
Making a Porsche that powerful is not cheap and will not run on pump
MK
Old Apr 2, 2008 | 12:59 PM
  #415
Originally Posted by WOODTSTER
A ford GT TT engine.
MK
Exactly... I just found out that now he wants to do all this on pump gas... forget about it.... 3.6L motor with big turbos at 1 bar on pump gas does not make 700 rwhp....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 2, 2008 | 01:07 PM
  #416
Makes sense guys. In laymans terms, the valves are being actuated against more cylinder pressure and must be supported by stronger springs... correct?
Old Apr 2, 2008 | 06:13 PM
  #417
DERBOOST's Avatar
Yes, correct....
Old Apr 4, 2008 | 03:40 AM
  #418
GT RUS's Avatar
MK
Ok so that is impossible then...cause some people here said that they beat mod FORD GT making over 800 HP...
OK what set I up do I need to have to beat ENZO, mod SLR or CGT ???
Old Apr 4, 2008 | 09:52 AM
  #419
unvmy996's Avatar
Russ , to get those big numbers u need to run race gas ... i dont think theres anyw ay around it .... well unless u perfect water meth injection....
Old Apr 4, 2008 | 10:09 AM
  #420
WOODTSTER's Avatar
SLR would be easier since it is already pressureized.
