A running pictorial of my monster Protomotive build
Old May 9, 2007 | 06:37 AM
  #346
buddyg's Avatar
Congrats on the numbers Scott that thing is a monster! What is the max power on pump gas, 93 octane?
Old May 9, 2007 | 07:47 AM
  #347
WOODTSTER's Avatar
HOLY DAMN **** !!!
And that is Rear Wheel Horsepower, that car is going to kick some
*** when it hooks up!
Congrats Todd and Scott,
Marty K.
Old May 9, 2007 | 08:52 AM
  #348
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Originally Posted by WOODTSTER
HOLY DAMN **** !!!
Marty K.
Wood, your gonna have to re-evaluate who is the new King .
Old May 9, 2007 | 02:37 PM
  #349
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Scott,
I have a question (which you may or may not be able to answer). You gained an astonishing 250 HP between .8 bar and 1.36 bar (an increase of .56 bar). That's over 40 HP for every .1 bar. In contrast, I vaguely recall that Markski picked up approximately 170 HP between .8 bar and 1.5 bar (a .7 bar increase). That's approximately 25 HP for every .1 bar. Given that Markski has larger turbos, larger heads/valves and a higher rev limiter, I would expect him to pick up more power than you as boost is increased. Any idea why you pick up so much more power than Mark?
Craig
Old May 9, 2007 | 02:57 PM
  #350
Originally Posted by Craig
Scott,
Craig
Yes we have an answer for that and the flat spot as of yesterday.. Scott's new dunos will look a little better. In the future I will have my car redone as well.
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 9, 2007 | 05:34 PM
  #351
TRK's Avatar
TRK
TRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to behold
Craig,
On Markski's we saw 871.63 at 21.5psi of boost, 1.48bar, and 685.16 at 14psi, .964bar
So... (871.63-685.16)/(21.5-14)= 24.86hp/psi increase, which is quite typical... We've seen up to 30 when the engine hits a sweet spot. Or to convert to .1bar would be 24.86hp/psi x 14.511psi/bar / 10 for .1 bar inc. = 36.07hp/.1 bar.
From 14 to 16psi it was (733.97-685.16)/(16-14)=24.405hp/psi, or 35.41...
On Scott's, we're seeing incremental increases as well, from 16.73 to 18.48psi, it ran 735.6 to 782.6hp, or 26.85hp/psi, or 38.97hp/.1bar.
From some of the lower boosts to the mid to high there were larger increases, some smaller... From 18-20psi, there wasn't that good of an increase due to the compressors running out of flow. They're only 52lb compressors, good for 104lbs for both. We typically see around 9.25hp/lb on these engines, and we netted a little more than that... 9.38 on this one, so 104 x 9.38 gave us a total of around 976hp to the crank. I thought we'd only get maybe 925-950 for around 780 to the tires, but it's pretty happy on rpm's. Notice, we're not making the tremendous torque you see on some other dyno sheets published because we're just not requiring that much boost to hit these power numbers.
Vralexanders engine did similar things.. From low boost numbes, the efficiencies were good, but not great, but as the boost went up, the fuel got happy and it increase in efficiency till we ran out of fuel...
Old May 9, 2007 | 05:45 PM
  #352
WOODTSTER's Avatar
The mad scientist has spoken,
take advantage and soak it up. I learned more in my overnight
stay at Protomotive about turbocharging than I have in all my time
spent on Rennlist/6speed combined. Good stuff!
thanks Todd!
MK
Old May 9, 2007 | 07:09 PM
  #353
Divexxtreme's Avatar
Dyno tuning is complete. The car made an amazing 830 rwhp / 780 rwtq at only 1.41 BAR...where the turbos finally ran out of boost.
Here's the graph of my final numbers overlayed over Jamie's for comparison. Jamie is at 1.5 BAR, I'm at 1.41 BAR.
Old May 9, 2007 | 07:21 PM
  #354
Craig's Avatar
Thanks for the explanation Todd, although most of it admittedly went over my head.
Congratulations Scott . . . those are great numbers!! Is Todd using a dynopak?
Craig
Old May 9, 2007 | 07:25 PM
  #355
Yes..DynaPak. Thanks, Craig.
Old May 9, 2007 | 07:52 PM
  #356
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Great numbers Scott. You know everyones waiting for that 9.xx pass. Im personally more interested in what your going to trap in the 1/4.
So, did you run out of fuel or did higher boost produce nothing more(I thought 3076's could take a little more than 1.5 bars? no?)
Redline is 7600?
Thanks.
Old May 9, 2007 | 07:55 PM
  #357
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
So, when do you pick it up? Can't wait to see the 1/4 numbers, as well.
Old May 9, 2007 | 07:57 PM
  #358
RCNJ's Avatar
RCNJ is infamous around these parts
Congrats Scott!
Awesome numbers
Old May 9, 2007 | 07:58 PM
  #359
Ran out of turbo. The motor is so efficient, they ran out of steam much earlier than we expected. Plenty of fuel left.
I could always switch to GT35's and make another 70 rwhp or so...but we want to see how the GT30's are on the street and strip...where it really matters.
Redline is 7,800. The turbos stop making power past that point, so there's no reason to go higher.
Car should get some time on the strip in Tulsa this weekend. I'll have her shipped home next week.
Old May 9, 2007 | 07:59 PM
  #360
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Scott,
This is absolutely awesome and you must be thrilled. Be careful with this thing. Can't wait to see this thing run. I am going to stick my neck out and guess this car lays down a 9.85 at the strip. This will require some fine launching and throttle control on your part. I can only imagine how this thing pulls. This Todd gentlemen is truly cutting edge for building these custom setups. I like it when things work without having to blow **** up several times while learning. Enjoy my friend and stay safe.
