A running pictorial of my monster Protomotive build
Now peak number-wise your at 824 at 20psi and Markski's at 871 at 21.5.
I dont know what the area under the curve is like but at 21.5 psi, it seem like your gonna be right with Markski. Is this because of the injectors maxxing out?
Are there any plans for custom larger injectors?
Originally Posted by Craig
Interesting observation. I just checked and my torque does not fall off any where near to the extent of Jamie or Scott. I suspect Todd will tune out some of that as to Scott.
Craig
Craig
Are you all using the same size hot sides?
Sounds dumb, but are you guys using cats?
What size downpipes and size/type of muffler?
Granted a very extreme example... on a Viper making 25psi, going from 3" full exhaust with mufflers (no cats) out the back, to opening a 4" dump picked up over 200rwhp and made it spool quite a bit quicker.
Letting it breathe post turbine can be worth huge HP if you know how to tune around it.
NIIIIIIIICE HP numbers DX.
So far, the car has made the following at the below listed boost levels:
0.77 BAR (11.3 psi): 589 rwhp / 561 rwtq
0.86 BAR (12.5 psi): 596 rwhp / 575 rwtq
1.00 BAR (14.5 psi): 693 rwhp / 641 rwtq
1.03 BAR (15.0 psi): 707 rwhp / 664 rwtq
1.10 BAR (16.0 psi) :735 rwhp / 680 rwtq
1.24 BAR (18.0 psi): 782 rwhp / 722 rwtq
1.31 BAR (19.0 psi): 813 rwhp / 73? rwtq (waiting on graph)
1.37 BAR (20.0 psi): 824 rwhp / 76? rwtq (waiting on graph)
For the sake of comparison and to show just how much my heads and cams are helping; Jamie's car with the same intake, turbos and exhaust that I have (but on stock internals) made 715 rwhp at 1.5 BAR (21.75 psi).
Here's the 1.02 BAR (15 psi) graph....
And here's the 1.1 BAR & 1.24 BAR (16 & 18 psi) graph...
Geetee - No plans on swapping injectors at this time.
Vicious - Same hot sides, I'm not running cats (I don't think Jamie is, either), custom Protomotive muffler (with 3" piping, I believe).
Thanks, Alex!
Thanks, Andrew! Need to take you for a ride one of these days, bro.
Thanks, Alex!
Congratulations Scott. How much torque did it make? Do you have a dyno graph?
Craig
Craig
He did say that he needed to swich to C16 at this level, though. He said at 19-20 psi, the car was starting to get knock-sensitive. He said he likes C16 MUCH better.
You have any track dates starting to line up?
Originally Posted by Alex
Are you planning on spinning it to 8000rpm?
