A running pictorial of my monster Protomotive build
Old May 5, 2007 | 02:31 PM
  #271
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
They are an aluminum matrix material, very similar to the factory heads composition, so I'm told.,Sonny.
Old May 5, 2007 | 04:06 PM
  #272
sharkster's Avatar
Originally Posted by Divexxtreme
Not yet, Dickie. But you'll be one of the first people I'll call when it is. We need to videotape a couple of runs in against your 997TT.
Dammit that's not fair! Pick on someone your own size
Old May 5, 2007 | 07:32 PM
  #273
Acropora's Avatar
Acropora has a spectacular aura aboutAcropora has a spectacular aura about
O Ring = Niro Rings?
Old May 5, 2007 | 07:44 PM
  #274
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
How are the piston rings in these cars. Are they decent from the factory to use in a built motor or are an aftermarket ones used used? I'm not talking about reusing the old ones, but just using the actual Porsche rings they come with.
Old May 5, 2007 | 08:23 PM
  #275
Divexxtreme's Avatar
Mine are OEM.
Old May 6, 2007 | 07:47 PM
  #276
Update:
My car just made 589 rwhp at it's lowest boost setting (.8 BAR/11.5 psi...boost controller turned off) at only 7,700 rpm. Should hit 600+ rwhp if/when we increase rpm. More numbers to follow as tuning progresses.
Old May 6, 2007 | 07:50 PM
  #277
CARVER's Avatar
CARVER is infamous around these parts
Nice bro, nice response!
Old May 6, 2007 | 07:52 PM
  #278
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Damn. Nice numbers. What RPMs are you planning to run up to? What'll be the max boost?
Old May 6, 2007 | 07:53 PM
  #279
buddyg's Avatar
Sweet Scott! What will that translate to at 1.5 bars and race gas? Isn't there a generic formula for every .1 bar to give you an idea?
Old May 6, 2007 | 07:56 PM
  #280
geetee's Avatar
I just noticed the GT3076r. Aren't you running a GT35?
Old May 6, 2007 | 07:59 PM
  #281
Nice Scott.... Can't wait for the final outcome...
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #282
Buddy, GT,
We are going to see how she likes it up in the higher boost range. I want 1.7-1.8 BAR, Todd wants 1.5.
Figure 32-35 rwhp for every 1/10th BAR increase. So at 1.5 BAR (assuming only 32 rwhp per 1/10th BAR)...I'm guessing 815+ rwhp. At 1.7, we *could* see 875+ rwhp.
More to follow.
Old May 6, 2007 | 08:02 PM
  #283
No. Todd would prefer me to run 35's, but I insisted on the 30's. I want less lag but with higher boost to make the same high numbers. Against the Protomotive philosophy, yes....but we worked it out.
Old May 6, 2007 | 08:03 PM
  #284
Thanks Andrew and Mark. I can't wait to see the next set of numbers!
Old May 6, 2007 | 08:10 PM
  #285
geetee's Avatar
I see. So your hitting full boost around 4500 vs. 5000 rpms with a GT35?
