A running pictorial of my monster Protomotive build
Derboost is right on with the boost thing. Figure, if you have a 2" inlet valve, the surface area is pi r ^2, or 3.14159in^2, and at 1.5 bar of boost, you'll have 68lbs of pressure trying to force the valve open... Well, if you only have 80lbs or so of seat pressure, the valve is just barely sealed, where on a gt3, you'd have the full force of the spring applying to seating the valve.
However, the gt3's also have another advantage that allows for lighter springs. The lifters are maybe 1/4 of the weight of the 996tt's as they not only don't have the variable lift stuff going on, but also are smaller in diameter. The rsr's go even further and remove the hydraulics and have a mere shell as the lifter, so with the same spring, they have proportionately higher rpm capability just due to the lower mass of the system involved.
What about the issue of the GT3 cam's NA ideal lift and duration versus the ideal lift and duration for a turbocharged motor. In addition, Porsche cams are notorious for harmonic distortion.
Wouldn't cams designed for turbocharging along with minimum harmonic distortion require less spring pressure?
Scott was asking $105K. Hope that answers your question.
