1.2 full boost???
Old Jun 1, 2007 | 10:35 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
1.2 full boost???
hit 1.2 boost should i be scared?? temp was 81 gag was 100oct. kevins k16s europipe, scargo headers (lg tubes)giac, evo air box ,sharkwerks plumbing to turbos , evo hoses and ics. well not sharkwerks evo stuff got it from alex... is this to much boost for stock interenals???
Old Jun 1, 2007 | 10:37 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
I do not think so, ... you have EVO IC.
Old Jun 1, 2007 | 10:38 PM
yep got em 3 months ago...
Old Jun 1, 2007 | 10:43 PM
got em from alex at sharkwerks along with the plumbing .. the larger air intake to the turbos really made a difference
Old Jun 1, 2007 | 11:12 PM
Turbo Fanatic's Avatar
Do you have a Program? or did I miss that? K16/24s or K24s and the corresponding flash should be good for 1.2 BAR. I get a split second 1.3 BAR display in gears 3+ for a split second while the Wastegates do their thing... then 1.2BAR all the way to redline.
Old Jun 1, 2007 | 11:15 PM
giac flash. just worried about rod pins or stretching
Old Jun 1, 2007 | 11:53 PM
Zippy's Avatar
Steve, I don't think you will have an issue stressing the internals too bad with K16's, assuming Kevin's K16's are making < 600 WHP. Have you discussed with Kevin if 1.2 bar is within the efficiency island (I heard Todd K use this phrase ) of his turbos. I'm guessing it is.
Old Jun 2, 2007 | 07:00 AM
WOODTSTER's Avatar
They obviously are making less that 600 wheel horspower (700 crank) with a K16 based
turbo, they in no way could flow that much air thru such a small turbo.
You are probably just at the end of the efficiency island (Kevin could tell you), the good news is you use 100 octane. I bet you are pulling strong
above 1.0 bar. Very Nice set-up !!!
MK
Old Jun 2, 2007 | 08:59 AM
turn it up to 1.3 bars LOL
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 2, 2007 | 09:05 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
I run 1.3 bar with evo stage 4, zero problems
Old Jun 2, 2007 | 09:48 AM
Then...
Do you fill the car crispier, sharp and more boost responsive with the IC?
Old Jun 2, 2007 | 09:56 AM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
1.2 is perfect. Does the car feel like it's pulling timing?
Old Jun 2, 2007 | 10:10 AM
ixlr82's Avatar
Member
ixlr82 is infamous around these parts
Same here, I see 1.3 BAR for a little longer but nothing less than 1.2 BAR with my foot all the way in it.
Old Jun 2, 2007 | 10:51 AM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
I thought you have a GT700... no?
Old Jun 2, 2007 | 08:07 PM
thanks guys feel safer now 1.3 was a little scay , car seems to pull hard but i must admit i always feel the need for more hp.. poss it the 81 degrees thanks steve
Rguy
Apr 12, 2020 11:11 PM
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
holmesatx
Sep 2, 2015 11:32 AM
