Procedure to eliminate the malfunction light from the spoiler.
Old Oct 16, 2014 | 05:37 AM
  #136
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Originally Posted by 03EvoIII
Hey guys. I have tried the fixes listed here and still getting this damn 'spoiler failure light'. I spliced both the upper and lower micro switches together. The light did not go away! Here is a pic of what was done previously.. Not sure what do with this! Thanks !!
yikes.
Old Oct 16, 2014 | 10:53 AM
  #137
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
^ lol thanks...Thinking I should take that red wire out? The blue/green wire pin was taped up. Not sure what the red wire ties together.
Old Oct 16, 2014 | 11:03 PM
  #138
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I removed the rams and spoiler and prefer running with out them, just the fixed lower ducktail. So I don't get the warnings and lights I mini zip tied one microswitch lever closed. I believe its the lower one, but try either.
Old Oct 17, 2014 | 12:31 AM
  #139
03EvoIII's Avatar
I went ahead and did it all. The hydrolic pump was still in there so i took that out and all associated wires. Its all nice and clean looking now. I will check tomorrow to see if the malfunction light is gone...fingers crossed!
Update: Spoiler malfunction light gone for good!!!
Nick49 - what do you do about the holes that are left from the rams?
Old Oct 17, 2014 | 02:11 PM
  #140
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
I believe the fix is different for '01 models compared to 02+ which is what causes a lot of the confusion. For me on my 2001, I just had to leave both switches open (by removing them from the holder)
Old Oct 17, 2014 | 02:29 PM
  #141
03EvoIII's Avatar
It's funny...because I tried to do that with the micro-switches from the start...but for some reason it didn't clear the light. Thinking it was crappy wiring done previously that was causing it not to clear. I removed the old HEAVY pump that sits behind the fan cover. No wonder why the trunk WAS so heavy! LOL
Old Oct 17, 2014 | 07:26 PM
  #142
nick49's Avatar
I've left the holes for the last couple of years and admit it looks like something is missing to those in the know. Those that don't know any different think it's normal.
My plan from the day I removed the rams and wing was to make a cover or plug. I made a template out of heavy paper actual size for reference. I thought about cutting some out of aluminum and rolling them to the exact concave shape then painting them satin black and gluing them in with silicone. I also thought about making a mold and casting some out of a black elastomer polymer and just pushing them in.
I'll get around to it sometime:-)
Old May 30, 2016 | 09:19 AM
  #143
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
Updated solution for me:
https://www.6speedonline.com/forums/...ml#post4521812
To remove the wire, pull the yellow cap and you will see the image below.
There are small tabs you need to deflect with a small screwdriver while pulling on the wire you want removed.
Pict of completed wiring (note this didnt work for me but in combination of the rennlist link from above did work).
Old Apr 7, 2023 | 06:24 AM
  #144
Rahul Singh Dobal's Avatar
Rahul Singh Dobal is infamous around these parts
Hi,
​​​​​I have 2001, 996 turbo model.
model. My spoiler works perfect with the switch, but when I hit the speed spoiler extends but does not retracts , so there is warning in cluster. Here in these threads there is lot to digest. So I am confused,
1. Can I unplug both the wires from microswitch & leave it, warning will go away ?
I am not going to buy aero kit, just do not want the warning to go away ..
If this does not work I guess I have to buy the aero kit wiring , do they sell separate wiring ?
Thankyou
Old Sep 8, 2023 | 02:50 PM
  #145
Mr.TT's Avatar
Mr.TT is infamous around these parts
Additional info for future people looking into this:
If you look at post #107 there is a comparison between the aerokit harness and the gt2 harness. I put a GT2 wing on my car and it came with a GT2 harness. I can confirm that the GT2 harness DOES create the spoiler warning. I can also confirm that jumping pins 2 and 5 on the GT2 harness solves the problem.
So for those sourcing harnesses instead of using the turbo harness, the GT2 harness is also an acceptable solution with some light modification. I pulled the pin from the engine light as it was not being used anyway and repurposed it to create the 2 - 5 bridge.
Old Sep 9, 2023 | 05:28 AM
  #146
There is a solution by Rennkit called the MicroModule Device.
991carreradriver
Aug 30, 2015 04:16 PM
spreeon
Aug 27, 2015 08:14 PM
GSR Autosport
Aug 26, 2015 05:20 PM
Nissan GTR
Aug 19, 2015 02:11 PM
